07-05-2020, 08:21 AM | #1 |
13
Rep 16
Air Suspension Issue Following Jacking
I harmlessly jacked car to remove REAR tire (Lost Pressure due to NAIL)
I did not "warn" the info screen that I was about to jack up the passenger rear of car When I lowered car, Rear Suspension Air Bag would NOT reinflate Getting a failure message on main info screen Car is sitting lopsided and will not level!! Any suggestions? Thanks |
07-05-2020, 08:45 AM | #2 |
///M SubDriver
1837
Rep 2,784
Drives: 2017 M3, 2020 X7 40i
Try disabling, then re-enabling the air suspension system. With the ignition on and engine off, push up (or down) on the suspension level switch for 7 seconds - no more, no less. This will disable the system. You will know it is disabled because the green dash line will be gone. To re-enable the system, push up (or down) on the same switch for 7 seconds. That should reset the system.
I did this when I did a test fit of my space saver spare and had no issues with my air suspension when I was done.
///M3 COMPETITION 6MT - 2017 F80 Smoked Topaz Metallic
BM3 / MP-HAS / GC Camber Plates / Carbonstructure Interior X7 XDrive 40i ///M-SPORT - 2020 G07 Arctic Grey Metallic X3 XDrive 30i - 2019 G01 Mineral White (wife's) / 128i 6MT - 2009 E82 Jet Black (son's) |
07-05-2020, 10:28 AM | #3 |
1064
Rep 1,420
First shalt thou turn off thy engine. Then, shalt thou count to seven, no more, no less. Seven shall be the number thou shalt count, and the number of the counting shall be seven. Eight shalt thou not count, nor either count thou six, excepting that thou then proceed to seven. Nine is right out! Once the number seven, being the seventh number, be reached, then thou shall re-enable thy Holy suspension system.
07-05-2020, 11:20 AM | #4 | |
4362
Rep 4,246
Current BMWs - '20 X5 xDrive40i M Sport, '20 BMW M550i | Past BMWs - '03 E39 540iT M Sport, '06 E53 4.8is, '11 E70 M Sport LCI
07-05-2020, 11:26 AM | #5 | ||
4362
Rep 4,246
Helpful as always m8.
07-05-2020, 11:39 AM | #6 | |
///M SubDriver
1837
Rep 2,784
But FWIW, the reason I was very explicit with the 7 seconds is that I have done several maintenance procedures in my BMWs where you needed to press a button for some number of seconds. But none that I remember had such a tight time tolerance as this procedure. In fact, the first time I did it, when I tried to re-enable the system, I needed a stopwatch to get the timing right ...
LittleJoe1064.00 |
07-05-2020, 01:40 PM | #7 | |
805
Rep 1,790
07-05-2020, 05:52 PM | #10 |
///M SubDriver
1837
Rep 2,784
Are you able to drive it? Do you have a suspension error message? It may re-enable itself. One time when I disabled it, I forgot and started driving. Once I realized I forgot to re-enable it, I noticed that it was back on again.
07-05-2020, 09:03 PM | #11 |
163
Rep 255
Drives: 2021 M-B GLS 580
The joy of air suspension.
2020 X5 M50i
2017 X5 50i M-Sport (Retired) 2013 X5 50i M-Sport (Retired) |
07-06-2020, 05:52 AM | #12 |
13
Rep 16
UPDATE:
I pulled fuses, replaced these (unblown) fuses Started vehicle, put into Sport then Comfort then Sport Started Driving Air Suspension re-leveled Miracle....No more Lo Rida! Lesson Learned - Always share my thoughts and feelings with my X7 and communicate them, especially when I am about to raise the vehicle to remove a wheel |
