07-04-2020, 10:44 PM | #1 |
Rep 48
Exhaust Vibration with Active Autowerke Muffler
Hi everyone, I'm hoping someone can help me with a problem with my recent Active Autowerke muffler installation. Although it sounds nice, it has introduced a new vibration in the 2000-2800 RPM range. It's as if the whole car is buzzing, and I feel like it's making all of the car's small rattles get even worse. Is there anything that I may have done wrong while installing it? It's an N20 X-Drive and I used an exhaust clamp as opposed to welding. The vibration is non existent at RPMs above 3000. Thanks in advance!
07-05-2020, 02:01 AM | #2 |
724
Rep 943
Drives: F30 328i Msport
I had a similar issue with my muffler delete, midpipe was hanging too low and hitting the chassis brace under certain rpm’s, Switched to the AA exhaust and it fit like a glove and no more rattling. What i think it is you’re feeling is the drone which is minimal compared to a muffler delete, and is actually enjoyable since it just fives the exhaust note a little beefier note.
trentr986.50 |
07-05-2020, 07:19 PM | #3 | |
32
Rep 54
A few questions: - Is your car automatic or manual? - if auto - try moving from sport mode to comfort / eco. Do you see a change Lastly - a clamp vs welding is no issue - double check the clamp. There isn't that much you can screw up though with the AA exhaust. Here is my install video for the 335 dual exhaust on my 328 |
trentr986.50 |
07-06-2020, 03:12 PM | #4 |
Rep 48
thanks for the input! My car is an automatic and changing the modes makes no difference. Most of the vibration is either while on gas semi hard or off gas completely. Giving a very slight amount of gas (just so that there is no engine breaking) makes the vibration mostly go away.
07-07-2020, 12:46 AM | #5 | |
32
Rep 54
I did two things to resolve this on my car: 1) Added some extra sound deadening 2) installed the stock exhaust valve in the AA exhaust Both of those videos are on my channel. Good luck |
alohasurftoad3081.50 trentr986.50 |
