07-03-2020, 10:58 AM | #1 |
Rep 21
Target boost N26 Stage 1
Hey all,
I tried my best to find a definitive answer on these forums for the following, but answers are all over the place. That said, I will copy and paste my question to Bootmod3 and answer received by them. Any input from this community is greatly appreciated. My question: "I am considering an ecu tune for my 2016 328i n26. I am considering a very conservative tune of +2 or 3 psi over stock so that I don’t have to worry too much about premature internal engine component wear or installation of required bolt-ons such as intercoolers, downpipes, etc. I see that BM3 is a very popular ecu flash platform. You have a couple of maps that I am interested in. You list (I believe) 3 conservative OTS maps – stage 1 93, stage 1 91, and stage 1 91 ACN. What is the approximate boost increase for the 3 maps?" Their answer is as follows: "Thank you for reaching out to us. The boost target for those maps is around 17-19psi." Thoughts? Thanks again! |
07-03-2020, 09:33 PM | #2 | ||
32
Rep 54
Does that help? |
07-03-2020, 10:10 PM | #3 | |
Rep 21
The reason for my confusion stems from what was told to me by a particular mechanic. He stated that stage 1 BM3 adds 4-5 PSI of boost. Seeing as stock boost for the n20 is (I believe)16-17, I thought his estimate was a hair high. Similarly, I was surprised to see a target boost of 17-19 given to me by PTF, considering 17 is nearly identical to the stock boost target. I feel like I am missing something here. Just trying to learn! Last edited by JoeCav; 07-03-2020 at 10:16 PM.. |
07-03-2020, 11:45 PM | #4 | ||||
32
Rep 54
07-04-2020, 12:01 AM | #5 |
724
Rep 943
Drives: F30 328i Msport
Thats peak boost, which is slightly higher than stock on stage1, the difference is that you get more time on higher boost through the rev range vs stock mapping
07-04-2020, 12:10 AM | #6 |
212
Rep 500
n20 Stage 1 Oct 91 here and based on my log the target is 20.8 psi for WOT. You will exceed the target boost sometime and the max I see is around 21.5 psi. Read on some thread regarding stock internals for N20 should be OK to handle up to 23 psi.
BrysonDM53.00 |
07-04-2020, 05:31 AM | #7 | |
Rep 21
Thanks for letting me know what you are experiencing. |
07-05-2020, 08:41 PM | #8 |
93
Rep 338
Yeah the most so far that i see at 100% throttle angle around 5500-5700 rpm's is 18lbs of boost on stock stage 1 - 93
2013 320ix N20 8AT|BM3 stg1|Muff Res Delete|HPB-LED-Amber-DRL's
IG: DadzBmer_N2o |
07-05-2020, 09:04 PM | #9 |
32
Rep 54
07-06-2020, 10:27 AM | #10 | |
93
Rep 338
IG: DadzBmer_N2o |
07-06-2020, 05:57 PM | #11 |
212
Rep 500
07-07-2020, 02:38 PM | #12 |
Rep 21
Thanks for the responses guys.
I'm on the fence about running the stage 1 OTS tunes. I'd like to see more logs indicating how the tunes set target boost, MAP response to said target, AFRs, and throttle cut-off when overboost is detected. I'm probably overthinking things, but this is where I'm at! |
07-08-2020, 09:48 AM | #13 |
2000
Rep 3,680
Stage 1 OTS is a very safe tune, you have nothing to worry about running it, or even running stage 2 for that matter. I've been on Stage 2 for around 15k miles and my blackstone oil analysis came back showing below average wear metals for my car's mileage (87k).
To answer your questions though: Stage 1 93 targets 19psi at the MAP at peak rpm which is about 5500rpm. Stock targets about 17. Stage 2 targets about 22.
Instagram: rjd_f30 | Current: EBII 2013 335i 6MT RWD & Sprint Blue 2008 Audi RS4 | Retired: 2013 328i, 2000 XTerra, 2022 Civic Si |
07-08-2020, 12:38 PM | #14 |
93
Rep 338
And honestly, if you wanna play it real safe and save ur pocket money, you could get the plug n play: BMS - JB+. Its supposed to give you about 25-35hp's for only about $200-300 ish.
IG: DadzBmer_N2o |
07-08-2020, 02:07 PM | #15 | |
Rep 21
It would seem a true tune is the better course of action, yes? As a follow up question, is there any advantage of running 93 octane on a 91 octane tune, say from a knock/timing perspective? Sorry, I didn't even know what Bootmod3 was 2 weeks ago. I'm just learning here! Last edited by JoeCav; 07-08-2020 at 02:34 PM.. |
07-09-2020, 09:54 AM | #16 | ||
93
Rep 338
IG: DadzBmer_N2o |
07-13-2020, 11:54 PM | #17 |
1889
Rep 5,506
If you want to be real conservative, you can run the ACN 91 tune and use 91 or 93 octane. It's designed for the crap gas we get out in California but it'll work fine for higher octane.
ACN 91 is the most conservative tune you can get with BM3 but it is still way faster than a Dinan Sport plug in.
Auto Detailing Enthusiast!
07-21-2020, 08:17 PM | #18 | |
93
Rep 338
IG: DadzBmer_N2o |
07-23-2020, 12:24 PM | #19 |
1889
Rep 5,506
Ran like crap as in not much power or ran like crap because it was causing pinging?
07-23-2020, 06:00 PM | #20 |
93
Rep 338
It was hesitating here and there with a rougher idle (rpms dipping and going back up)..i ran this tune for less than a week and flashed it back to my 93, don't have those conditions anymore.
IG: DadzBmer_N2o |
07-28-2020, 02:45 PM | #21 |
1889
Rep 5,506
Strange, I never had any issues. I pumped a few gallons of 100 octane to bump the octane up above 93 octane for fun and the ACN91 stage 1 tune still ran fine.
07-28-2020, 04:49 PM | #22 |
54
Rep 185
If your going to go with a bm3 conservative tune, you might as well go with the bms Jb+ It’s only $199 brand new and you can add 3-4 psi over stock. I think it’s the best mod for the money
