07-02-2020, 07:24 AM | #2 |
8245
Rep 16,088
Do you mean MAF? https://www.newtis.info/tisv2/a/en/f...-unit/IKT1Ffp4
07-02-2020, 07:26 AM | #3 | |
24
Rep 199
07-02-2020, 07:57 AM | #4 |
8245
Rep 16,088
Newtis doesn't list it. Perhaps the intake pipe pressure sensor? https://www.newtis.info/tisv2/a/en/f...ensor/HkWIjFth
https://www.newtis.info/tisv2/a/en/f...units/IKFwDE9l |
07-02-2020, 08:00 AM | #5 | |
24
Rep 199
07-02-2020, 09:55 PM | #6 |
212
Rep 500
The photo you show should be manifold MAP sensor after the throttle control. There's another MAP sensor on the charge pipe which is pre-throttle pressure. Here's the photo for MAP sensor on charge pipe (pre throttle boost if you read from the BM3 log file).
alohasurftoad3081.50 |
07-03-2020, 03:17 PM | #7 |
Rep 1
They're actually boost pressure sensors. The one before the throttle body measure pressure, then there's on mounted on the intake manifold and it measures pressure and temperature.
