06-29-2020, 10:30 AM | #1 |
41
Rep 106
Oil catch can....worth it?
I feel like I Googled this to death and still came away with a maybe. Is it worth adding an oil catch can to my 2016 328iX GT? And if so, do I spring for the nice machined Burger one or just an inexpensive one off eBay or Amazon? I don't drive the car hard, but it's my commuter and I tend to keep my cars at least 10 years.
06-29-2020, 11:20 AM | #2 |
8270
Rep 16,128
Looking in the wrong places you were.
https://f30.bimmerpost.com/forums/sh...tch+can&page=2 |
06-29-2020, 12:37 PM | #3 | |
41
Rep 106
08-31-2020, 02:31 PM | #4 |
41
Rep 106
Update: I recently installed an inexpensive catch can. It was simple to plumb in, but mounting it was a bit of a pain for me. My background is electrical, not mechanical so I maybe should have sprung for the $200 unit that comes with its own special mounting bracket and I would have saved myself some time, but bending and drilling some metal was not all that hard.
My wife thinks I am crazy as I drove the TL for over 13 years and did next to nothing to it and now I'm playing around with a 4 year old BMW lol. |
08-31-2020, 04:13 PM | #5 |
8270
Rep 16,128
I drilled two holes to install mine, total time to drill the holes, screw the mounting bracket in place and attach the can to the bracket 10 minutes. I didn't bend any metal.
https://billfitzmaurice.info/images/BMW/Catch Can.jpg I've got the feeling you made it a lot more difficult than you needed to. |
09-01-2020, 07:35 AM | #6 | |
41
Rep 106
09-02-2020, 10:45 AM | #7 |
1312
Rep 888
Just a heads up to be cautious if your winter temps get to or below freezing on a regular basis if you’ve installed an oil catch can. If so, you should remove the catch can for the winter or be prepared to clean it weekly due to the much greater amount of moisture in cold temps and the risk of freezing. You can damage engine seals if it clogs due to being frozen.
09-02-2020, 10:56 AM | #8 |
8270
Rep 16,128
I'd say the risk there is slim to none. What collects in the can in the winter is a mix of oil and water, the source of the water being condensation that collects in the oil pan and then makes its way to the catch can as water vapor and condenses there again. Once in the catch can it can't make it's way out to the PCV other than as water vapor, and in no greater volume than could go from the crankcase directly to the PCV as water vapor if the catch can wasn't there.
09-02-2020, 12:16 PM | #10 |
8270
Rep 16,128
My comments are from personal experience. After a full winter my can accumulates at best three eights of an inch of mixed oil/water sludge. That presents no threat to blocking the PCV or blocking the air flow to the PCV. Knowing what accumulates in the can in winter there's no way I'd remove it. I want that sludge getting trapped in the can instead of making its way to my intake valves. If you drive a lot in winter it's not that big a deal to check the catch can dipstick every few weeks and empty the can as required. It's a very big deal to have to pull your intake manifold and use walnut blasting to clean the intake valves. As to the Turner instructions, the lawyer in me says that they had one guy who failed to check the can for a full winter of driving in the Yukon and had a problem, so to cover their ass from possible litigation they put that in there. But it makes no sense. The can does the most good in cold weather. Between April and November mine hardly traps enough oil than a single paper towel will wipe clean.
09-02-2020, 01:51 PM | #11 |
41
Rep 106
I'm certainly no expert, but I find it hard to believe enough moisture could be in there to freeze and block air flow. It does get cold here in New England, but not as frigid as some places. I garage my car when not in use so it shouldn't freeze overnight. I appreciate the heads up though and will certainly keep an eye on it during the winter.
I'm now curious as to what things look like knowing my car went nearly 50K miles without a catch can installed since I bought it used. |
