06-29-2020, 07:36 AM | #1 |
100
Rep 512
Is comfort access RELIABLE ?
Hi All
I set my car to "Lock automatically when I walk away. it has been working quite well, except a few times when I do walk away and it just does not work!! Does anybody have this issue? To open I just leave the key in my pocket and open with handle. I have not set comfort access to autoopen on approach. Anybody know why the autolock is not that reliable or had the same experience? Thanks |
06-29-2020, 07:42 AM | #2 | |
260
Rep 681
Mine is set to Auto Unlock and auto lock when walk to the car or walk away. Works, perfectly every time. Have you ever left the key or credit card key in the car? These might stop the car from locking.
G20 M340iX, Sunset Orange, Tartufo Merino Leather, Pretty Well Loaded, OEM Aero Kit, Drive Recorder, BlackVue Dashcams removed and replaced with ACE 2.0.
06-29-2020, 07:45 AM | #3 |
100
Rep 512
Hi Steve
Thanks for that. Interesting I carry the key card in my wallet, but have never left my wallet in the car. I will monitor this , it just happened tonight , I had the key with me and walked out the garage , normally a couple of steps out the garage it lock and the mirrors close, but tonight no lock I had to lock it manually. Maybe its too cold |
06-29-2020, 08:12 AM | #4 | |
49
Rep 359
06-29-2020, 08:14 AM | #5 |
100
Rep 512
Mmmm, thanks Slideit ...the jury is not yet out on this function, well at least on my car I thought it was sooo cool, but have had 2 failures so far.
06-29-2020, 02:57 PM | #6 | |
102
Rep 250
Walking up to the car it's fine. Walking away works 8/10 time. What I find is that it'll lock when I'm walking around from say the drivers side to the passengers side, close to the car, so if anything it's too sensitive. It has a number of times not locked when walking away as well. I have the bleep set so I know when it hasn't auto locked.
Current: 2020 M340i
Past: M140i, Z4 35is |
06-29-2020, 05:58 PM | #7 | |
100
Rep 512
Ah thanks for that del82 , glad to know that I am not the only one that has experienced this. When you say you have the bleep set so you know it has not auto locked, can you tell me which setting this is in the menu ? Thanks |
06-29-2020, 07:32 PM | #8 | |
162
Rep 305
The kick under the boot to open the boot is a bit finicky. |
06-29-2020, 08:20 PM | #9 | |
100
Rep 512
I think the trick with the boot is to do a medium speed kick aligned with the badge. But I agree, sometimes it does not work and it looks pretty stupid when people see you kicking the boot repeatedly |
06-29-2020, 09:37 PM | #10 |
133
Rep 259
I set it to only lock on walking away as a "back up". I'm used to touching the door handles and using the lock button on the boot lid to lock.
Turned off the unlock on approach function on the first week as it was locking and unlocking when I was wandering through the garage 😂 You gotta touch the door handle to open the door anyway! |
Ruka800.00 |
06-29-2020, 10:47 PM | #11 | |
100
Rep 512
I may follow the same process as you, always lock with the door handle and if I forget and walk away it should lock itself ...good approach I thought the tech was really nifty, you walk away and it locks voila no worries, but obviously some of us have a 80/20 hit rate, so you still need to check just in case. |
07-01-2020, 02:35 AM | #12 | |
Old Member
65
Rep 196
Drives: M340i, Mineral White
And if there is another key within about 6 metres of the car, it supposedly won't work either. But I have never had an issue with it on my car. I've got it set for lock only. I did have it set for unlock as well , but it drove me crazy... unlocking whenever I was nearby with the key. |
07-01-2020, 03:39 AM | #13 |
79
Rep 138
Yeah, mine is not 100%, so I turned on the beep on lock function so I can hear if it hasn't worked... it works maybe 8/10.
I do find that when parked in certain places, or I leave from certain positions/angles it's more temperamental too. I have a large wall at the side of the drive and if I walk in a certain position it never likes it 🤷🏻
J
330i M Sport Plus Previous- 435D M Sport |
07-01-2020, 05:08 AM | #14 |
166
Rep 272
If your phone, NFC enabled credit card, security swipe card etc get in the way of your key (same pocket or in between key and car somehow) then it doesn't work as reliably or at all.
Have you separated everything from your pockets and see if it still behaves weird? |
07-01-2020, 07:47 AM | #15 | |
100
Rep 512
Good advice |
Sergeant Skinner166.00 |
07-01-2020, 08:22 AM | #16 |
166
Rep 272
07-01-2020, 09:45 AM | #17 | ||
100
Rep 512
But it's a great journey !! |
07-02-2020, 04:32 AM | #18 |
100
Rep 512
Naah , turning off comfort access auto lock when walking away, just washed the car..hahahah.. the car was doing the autolock dance.. I could always leave the key far away.
My thoughts are , if i always have to doublecheck then I might as well just lock it manually on the door handle instead of walking away and hope it locks and then have to take the key out my pocket and lock it if it doesnt. i'm soo lazy hahaha |
07-02-2020, 04:37 PM | #19 | |
260
Rep 681
It will save all that locking/unlocking BS.
07-03-2020, 02:23 AM | #20 | ||||
100
Rep 512
07-03-2020, 08:56 AM | #22 | ||
97
Rep 473
__________________________________________________
On Order - 2022 BMW i4 eDrive40 M Sport Mineral White, Fully Optioned Current - 2019 BMW G20 330i M Sport Alpine White Retired - 2018 - Range Rover Velar SE D240 Retired - 2015 - Mercedes Benz C250d AMG Line W205 |
