Bimmerpost
4 Series
Technical Topics Wheels and Tires Ok to repair/replace one tire after 7.5K mi?
      06-28-2020, 09:31 PM   #1
patnaik
Drives: 2019 330i xDrive
New G20 owner here. There is a slow leak in one of the rear tires. The car came with Bridgestone Turanza RFTs and has only 7.5K miles on it. Is it ok to plug it? If not, can I just replace the one tire? I can get the exact tire at Tire Rack. Advise please. Thanks!
      06-28-2020, 11:03 PM   #2
Blubaron79
Blubaron79's Avatar
1431
Drives: 2021 M340i xDrive
If it were 2-3k miles, but not almost 50% of the tires life. It will kill the differential.
Current: 2021 M340i xDrive
Previous: '18 340i xDrive; '15 335 xDrive; '14 435i xDrive; '09 335 E92 xDrive
      06-29-2020, 01:30 AM   #3
warrenw
Food Critic
warrenw's Avatar
South Korea
1084
Drives: 19 AW M2C, 21 M340i
How much tread is left vs how much tread on the new tire? If there's a significant difference then replace both rear tires - that is if the tire can't be patched.
      06-29-2020, 07:38 AM   #4
patnaik
Thanks! I will be going to the dealership today for an oil change and I will ask them to check the tire and let me know how much tread is left. I know that they will recommend replacement. I will try to get it patched elsewhere.
      06-29-2020, 11:06 AM   #5
patnaik
The dealer said that the tire has a tread depth of 7/32" Tread depth for a new tire is 10/32" as per Tire Rack. Dealer recommends replacing the one tire with a new one. Is this OK?
      06-29-2020, 06:14 PM   #6
warrenw
Food Critic
warrenw's Avatar
South Korea
1084
I did this recently on my M2. 3/32" isn't enough to damage your diff or anything like that... I say go for it.
      06-29-2020, 06:58 PM   #7
JayDD007
104
Drives: BMW's
2020 G07 X7  [0.00]
2013 E70 X5  [0.00]
2003 E46 M3  [0.00]
2013 F10 M5  [0.00]
2009 E90 335ix  [0.00]
2009 E90 M3  [0.00]
The car will be fine with non matching tread depths, only problem would be if you've driven the tire while flat. This destroys the integrity of the sidewall.
      06-29-2020, 07:08 PM   #8
patnaik
No, added air when I got the warning message. The pressure was down to 29 psi.
Search this Thread:
Advanced Search
g20
