Motor Oil
06-24-2020, 03:05 PM | #1 |
Rep 23
Drives: BMW 328 (AWD)
Motor Oil
Just out of curiosity, what kind of motor oil do you guys use? I am currently using Liqui-Moly 5w-40. Switched from BMW 0w-30 that was filled by the previous owner from the dealership
06-24-2020, 03:09 PM | #2 |
2659
Rep 6,290
06-24-2020, 03:17 PM | #3 |
E82 Mudflap Ambassador
2214
Rep 2,219
Drives: '08 128i
BMW LL-01 approved oil.
End of thread.
My 2008 128i - Sparkling Graphite/Beige - Sport pkg - 6MT - Click me!
Parents' 2014 528i - Mineral White/Ivory White - fully loaded Instagram @Andreys_128i and @Honda.Bito |
06-24-2020, 08:00 PM | #5 |
1998
Rep 2,026
Drives: 2008 E92 328xi
I'm currently using valvoline 5w30 High Mileage because it has very nice specifications and film strength aswell as ability to cling to engine parts after its turned off which has eliminated lifter tick that I had with castrol 0w40.
Because I'm a fanatic I will go into the oils data sheet and look up testing for each one and compare. Really any oil that's ll01 approved will work fine for your engine, like hass said whatever is cheapest at Walmart and meets the spec. Try different ones see which you like better. Check out 540rat blog. I will be doing an oil analysis on my n52 on this valvoline see what they say how the engine is doing with an oil a bit on the thin end of the Xw30 spectrum and trying Mobil 0w40 next |
06-24-2020, 08:19 PM | #6 | |
996
Rep 2,287
It's well known that just normal service will keep these engines running well past 300k. What's the point? The rest of the car will be falling apart by then. Walmart Mobile one European formula @ $25.00 a bottle is fine. Put 200k on my N52 and the oil consumption was near nothing. |
06-25-2020, 12:18 PM | #7 |
3973
Rep 7,215
yeah, I don't buy that you really need an LL-01 oil. BMW oil specs change all the time - like, are you going to put a watery LL-01 into an S54, or into a 30 year old M20B25? I don't think so, but that's what BMW "specs". You'll wipe out the cam lobes on an M20 in short order running the BMW approved oil.
I don't have oil consumption or ticking issues. I still run the M1 European formula. But, whatever makes you happy. |
06-25-2020, 01:17 PM | #8 | |
2659
Rep 6,290
06-25-2020, 01:24 PM | #9 |
1998
Rep 2,026
Ll01 is more about using a high end synthetic oil to ensure it holds up and doesn't break down over the long oil change intervals these cars use as per the dealer maintenance programs and bmw recommended intervals. There's no reason to not go for an oil that will hold its specs for longer than the others if you can for the same price.
06-25-2020, 02:26 PM | #10 | ||
3973
Rep 7,215
They're fine for engines like the N52 - which were designed with thinner oils in mind. That doesn't make them "bad", but inappropriate for older engines IMO. Quote:
06-25-2020, 02:27 PM | #11 |
2214
Rep 2,219
Drives: '08 128i
Luckily Walmart usually has Castrol (LL-01) or Mobil 1 (used to be LL-01) euro formulas for dumb cheap so just buy that.
hassmaschine3972.50 |
06-25-2020, 03:04 PM | #12 | |
2659
Rep 6,290
Also both LL01 oils I've been using people on BITOG were saying they really good. Castrol 0W-40 and now switched to Pennzoil Euro plat 5W-40. |
06-25-2020, 03:39 PM | #13 |
148
Rep 20
I had the oil changed recently, used LL-04 approved Castrol Magnatec 5W30. In my E46 I used Mobil 1 with ESP formula, as long as its oil of a reputable brand with BMW approval it won't make a great deal of difference.
06-25-2020, 09:32 PM | #14 |
79
Rep 250
Drives: E82 N52 6MT A51
I use pennzoil platinum euro 5w40 - LL01. It goes on 50% sale quite often and has all the certifications you would ever need. (Bmw, merc, porsche, ferrari, and more). Its owned/rebranded shell oil for north america.
TheMidnightNarwhal2658.50 |
