BMW e90 (N52)Reliability
06-20-2020, 04:07 PM | #1 |
Rep 23
Drives: BMW 328 (AWD)
How many miles does your BMW have and what things have you replaced? What mileage? I am at 71k miles, replaced the valve cover gasket, all 6 ignition coils and (NGK) plugs oil pan gasket, oil filter housing gasket, rear shocks, front thrust arm bushings and the belt tensioner.
06-20-2020, 08:13 PM | #2 |
3973
Rep 7,215
Currently at 156k - since 99k (it had a battery and a starter before I bought it in 2014):
-spark plugs -1 coil -Waterpump @130k (still original t-stat) -belt tensioner -uhhh.... -a few oil/filter changes? -....... I did do the VCG, but only because I was installing MILVs; the original wasn't leaking. Otherwise, I wouldn't have touched it. OFHG isn't leaking, but I assume one day I'll have to do it. Otherwise, the only other failures on the car have been an angel eye bulb, the wiper relay ($15, it rains a lot here), and a flat tire. Basically it's a total POS. Shoulda just got a 335i for $1000 more. 🙄 |
Biginboca3763.50 |
06-20-2020, 08:26 PM | #3 |
3764
Rep 2,738
I replaced my serpentine belt and pulley and spark plugs as PM around 70k miles.
I did a valve cover gasket with MILV’s install. As part of that install I also replaced the valvetronic motor gasket, it ended up having to do that 2 more times within a year before I figured out how to install it so it doesn’t leak (RTV FTW lol) I installed a new oil filter housing gasket as part of my oil cooler install around 80k miles and might have to put another one in soon cause I think I’m seeing some weeping there. (I’m at 105k miles now.) I’m getting ready to do the water pump and coolant flush as PM cause like I said 105k miles now... Basically if you take mod installs out and what I’ve done as PM my car has needed nothing at all except oil changes.
06-21-2020, 08:58 AM | #4 |
96
Rep 406
Drives: S54/N52
Recently bought a 07 E91 with 72k miles
Oil pan gasket was already done by PO. Nothing was really having issues other than the ABS pump. -74k miles: Replaced the pump unit only with a low mileage unit for $100, good as new. -74k miles: AT filter and fluid change -Preventative 78k: changed belt, tensioner and idler pulley -Preventative 78k: changed WP, thermostat and several hoses This is my 3rd N52 engine and seems like its going to be a keeper (Just cuz its an E91). |
06-21-2020, 09:47 AM | #5 | |
Rep 23
How hard was doing the water pump? |
06-21-2020, 02:08 PM | #6 |
96
Rep 406
Drives: S54/N52
06-21-2020, 07:55 PM | #7 |
883
Rep 1,413
Major maint. around 70k for me was VANOS, VCG, ECS, Plugs, Coils, Tensioner
But I'm certain the guy I bought it from wasn't meticulous with the upkeep.
See you, space cowboy.
Supercharged |
06-21-2020, 08:46 PM | #10 | |
883
Rep 1,413
Like I said, I don't think the PO was very conscientious of the upkeep Aside from blowing the new motor up, I had zero issues after the fact minus a freak failure of a braking component
Supercharged |
06-25-2020, 03:36 PM | #11 | |
476
Rep 1,191
Drives: 2009 BMW 328i Wagon
I had a motherfucker of a time changing the water pump in my car. Some of its was my own stupidity and laziness (tried to do it without taking the radiator fan/shroud out at first...ain't gonna come out that way you guys), but the other really hard thing was getting the damn hoses off without breaking anything, they were stuck on there really hard. Oh and yeah, I got coolant everywhere. Every. Fucking. Where. If I were to do it again, I could probably knock it out in a couple hours, but it took me three nights straight of 5-6 hour sessions after work since it was my first time. |
desertman1232213.50 |
