BMW M5 F90 (2018+) General Forums iDrive, Nav, Stereo, Bluetooth, Electronics    Garage Door Opener Issues?
      06-18-2020, 12:54 PM   #1
Jamesmick
131
Drives: 2018 M5 Azurite Black
My 2012 535i is rock solid in opening any and all gates, garage doors, etc. using the universal opener buttons on the rear view mirror. It opens everything, every time and from pretty far away.
My 2018 M5, however, doesn't work well or consistently (and sometimes not at all). On the same gate (non-rolling codes), it won't open from as far away as the 535. Even more annoying is that fairly often doesn't open the garage doors (rolling codes).
That is, every so often the car/opener literally will not open the garage regardless of how close I am or whether I position the car directly in front of the garage, to the side, etc. When it happens I have to get out the car and walk inside to open the garage. Super annoying and frustrating and even more so because it is intermittent. I never know whether it is going to work.
Has anyone else experienced this? I'm wondering if it is the system itself or if I should try reprogramming them again? Or if I should have the dealer replace the module or something.
2018 M5 (current)
2012 535i Msport/Dinan (current)
2008 535i Msport (retired)
2003 530i (retired)
2000 C32 AMG (retired)
      06-18-2020, 02:29 PM   #2
kdeleon
94
Drives: M5
I don't have a solution, but I have a 2018 too and have no issues with opening my garage. It can't open as far as the original OEM remote, but still far enough that the door will be open by the time I pull up. Just a data point for you.
      06-18-2020, 02:39 PM   #3
Jamesmick
131
Thank you!
I might try programming them again to see if that helps. Such a bizarre issue and of course intermittent and without taking my garage to dealer, it will be impossible to recreate for them.
2018 M5 (current)
2003 530i (retired)
      06-18-2020, 03:09 PM   #4
kdeleon
94
Drives: M5
Some dealers were doing pick up service for quarantine. Maybe your dealer is too and you can show them when they pick it up.
      06-19-2020, 08:50 AM   #5
Jamesmick
131
Good thinking! I'll reach out and see. Thanks!
2018 M5 (current)
2003 530i (retired)
Search this Thread:
Advanced Search
m5post
