06-14-2020, 06:15 PM | #1 |
200
Rep 39
FYI: Software update failure bricks your car
Was out today and my wife's new 2020 X7 M50i said it's due for a OTA software update. So will I was at Dick's Sporting Goods getting my son a new tennis racket, I said ok to the update. I figured it was no big deal. I patiently waited while it did it's thing and at the end it said update failure. It totally bricks the car!! You can't turn it in and tells you to call roadside service. I was totally shocked and super pissed. Why would it not revert back to old OS? On top of that roadside took forever but the tow truck guy was awesome. But it gets even better... the car could not be put into neutral. In BMW wisdom they got rid of the neutral release mechanism , so the flatbed tow truck couldn't tow it. It requires a a repo type truck and lifts your car on top of casters and pulls it to the dealership. WTF!! Now our brand new car (2weeks old) is sitting a shopping center parking lot. My 6 th BMW, never had a problem until now. It seems the German engineers are loosing their minds that a software update can kill your car and strand you in the middle of nowhere.
Thanks,
DrVader |
06-14-2020, 09:09 PM | #4 | |
674
Rep 1,021
DrVader200.00 |
06-14-2020, 10:11 PM | #5 | ||
200
Rep 39
Thanks,
DrVader |
06-14-2020, 10:27 PM | #7 |
200
Rep 39
Thx bud, my M's have never given me troubles but getting my wife her first Beamer has not been fun so far. She asked me today why I didn't get her another GLS 550. 😩
Thanks,
DrVader |
06-15-2020, 07:32 AM | #9 |
///M SubDriver
1837
Rep 2,783
Drives: 2017 M3, 2020 X7 40i
I am curious if this (an iDrive reboot) would have helped too. That said, I agree that a failed OTA software update should not "brick" your car and leave it stranded. I am curious to see what is the root cause of the problem that led to this - and hopefully the solution is a relatively simple one. Hopefully it will not mean that OTA updates will go away as that functionality should not be that difficult to implement safely given the technology available today....
///M3 COMPETITION 6MT - 2017 F80 Smoked Topaz Metallic
BM3 / MP-HAS / GC Camber Plates / Carbonstructure Interior X7 XDrive 40i ///M-SPORT - 2020 G07 Arctic Grey Metallic X3 XDrive 30i - 2019 G01 Mineral White (wife's) / 128i 6MT - 2009 E82 Jet Black (son's) |
DrVader200.00 |
06-15-2020, 02:37 PM | #14 |
///M SubDriver
1837
Rep 2,783
Well, after seeing this unfortunate issue with the OP, I was curious about how to put the X7 into neutral and took a look. Apparently, F-series BMWs and older had mechanical unlock mechanism located inside the car close to the shifter. In most cases, it required using your emergency key to unlock the transmission to get it into neutral. But not anymore for the G-series cars....
The short answer is, yes, you can put the car into neutral if you have zero power or zero electronic control of the car (or a "bricked" car as the OP put it). The catch is you will need to crawl under the car, remove an underbody panel, and have at it with some "special" tools (or a few screwdrivers) to release the parking brake as seen here: https://www.newtis.info/tisv2/a/en/g...ock/1VndGenw4O Or, if you are lucky and have some power/control of the vehicle, there is a procedure you can use that involves the start button, gear selector and brake pedal that can be seen here (approx 3/4 of the way down the page): https://www.newtis.info/tisv2/a/en/g...pce/1Vncm8Z4Xj Then of course, there is the e-brake you have to deal with, which actuates automatically on the X7 when the engine is turned off..... https://www.newtis.info/tisv2/a/en/g...ake/1VncsiMYxk Either way a serious PITA, but probably better from a security perspective than the previous mechanical emergency override options. Of course, this "new tech" does not mean much if you are in a situation like the OP and you just want to "gidder done..." So in other words, the "drag" method will most likely be the only viable option. Ain't technology grand...??
06-16-2020, 12:03 AM | #18 |
4362
Rep 4,246
Exactly! I was cringing was looking for something to grab hold of cause the photos of getting it onto the flatbed looked painful.
Current BMWs - '20 X5 xDrive40i M Sport, '20 BMW M550i | Past BMWs - '03 E39 540iT M Sport, '06 E53 4.8is, '11 E70 M Sport LCI
DrVader200.00 |
06-16-2020, 09:00 AM | #19 |
1909
Rep 2,007
Drives: 2022 i4 M50
I believe the proper course of treatment for PTDS is to lay down some rubber. No M-XDrive on the M50i, but a few pulls might do the trick, and help even out the 17 or so feet of drag on those tires.
Current: 2022 i4 M50 | 2022 G07 X7
Gone: 2020 F92 M8 | 2020 G07 X7 | 2018 F80 M3 | 2017 F15 X5 | 2016 F16 X6 | 2015 F36 4 series GC |
06-16-2020, 09:42 AM | #20 |
Rep 22
Why in God's name did the tow truck company not use a couple of Go Jacks to get it on the Roll Back? I would never let a Tow company drag my X7! i live in a rural area and all our Tow companies carry Go Jacks or a similar product to load vehicles when they can't roll.
06-16-2020, 12:03 PM | #21 |
48
Rep 511
CruiseControl216.50 |
06-16-2020, 12:22 PM | #22 | |
674
Rep 1,021
