06-13-2020, 05:32 PM | #1 |
24
Rep 199
I am looking to tackle this on Monday. I have the ftp charge pipes and an eBay special fmic.
I read some people saying to others that they need to make sure they fit the o rings on the charge pipes? I am just double checking this is not the case for ftp charge pipes as they have them already built in? I don't want to be caught with boost leaks after fitting it all etc Also I bought my kit off eBay but just noticed in ftp website for the same kit you have option between manual and auto. I didn't have the option on eBay nor does it state what the application of the kit is for. Is there a difference on the n20? |
06-13-2020, 05:54 PM | #3 |
24
Rep 199
06-13-2020, 05:59 PM | #4 |
3082
Rep 4,333
06-13-2020, 06:01 PM | #5 | |
24
Rep 199
Did you reuse them or buy new? |
06-13-2020, 06:08 PM | #6 | |
3082
Rep 4,333
my ftp orings were in the box but not in the pipe. my car was young when i did it, so i just carefully pulled the OEM orings out and placed them in the FTP pipe. the OEM orings are more delicate and of a different style than what FTP gives you. before using the OEM orings i cleaned the oil off and put some tire dressing on them(wiped off the excess). i still have the FTP orings somewhere in my garage. |
06-13-2020, 06:11 PM | #7 | ||
24
Rep 199
I will trial fit it with the intercooler tomorrow . How tight should the intercooler and charge pipe be? |
06-13-2020, 06:18 PM | #8 |
3082
Rep 4,333
in your photo the green one has a little wrinkle at the 9:30 position. lightly massage it and make sure it's all uniform without wrinkles. the red one looks great. it will be fairly snug with a slight bit of play. when the pipe is pressurized the little flap will maintain the seal. that's why it needs to be without any wrinkle in the flap.
06-13-2020, 06:19 PM | #9 | |
24
Rep 199
Or do you have part numbers for oem in case I need to replace them? |
06-13-2020, 06:21 PM | #10 |
3082
Rep 4,333
go ahead and take the green one out and reinstall it. if the wrinkle exists i'd use the OEM one if its in good condition. just check the condition of the rubber.
the green one might be okay, even with the wrinkle, but lets say you determined you had a leak, that wrinkled part would be suspect. |
06-13-2020, 06:27 PM | #11 | |
24
Rep 199
Will report back of wrinkle goes or not. Do you know the oem part numbers for the set of rings from the pipes to the intercooler? |
alohasurftoad3081.50 |
06-13-2020, 06:31 PM | #12 | |
3082
Rep 4,333
okay, don't lose too much sleep over it. |
06-13-2020, 06:33 PM | #13 | ||
24
Rep 199
Pic from another angle. |
06-13-2020, 06:36 PM | #14 |
3082
Rep 4,333
it can come out. it's a replaceable part. you have to use a pick tool and be careful not to tear it. this angle doesn't look as bad. might be okay.
06-13-2020, 06:44 PM | #15 | |
24
Rep 199
Happy days. Will piece together with fmic tomorrow and see tightness is like? |
06-14-2020, 05:17 AM | #17 |
24
Rep 199
06-14-2020, 10:29 AM | #18 |
3082
Rep 4,333
Snugness is perfect.
It's not difficult, but the most difficult part is removing the black plastic retaining clip on the OEM charge pipe. You have to pull(or push) it towards the intercooler. I tried to make a videoclip with my OEM pipe, to no avail, sorry. Kies motorsport has video of the install on youtube. I'd review it 1st. |
06-14-2020, 01:21 PM | #19 | |
24
Rep 199
06-14-2020, 02:48 PM | #21 |
24
Rep 199
06-14-2020, 02:58 PM | #22 |
3082
Rep 4,333
Yes. Mine is auto. I'm not sure about manual. Ypu will have to get a some kind of cover and a worm gear clamp.
Or get aicraft metal speed tape and cover it from inside. Nicer flow |
