06-13-2020, 12:12 AM | #1 |
58
Rep 39
Semi-digital gauges look better than new ones
I just want to say that the semi-digital gauge option in the G30 actually looks better than the all-digital gauges in iDrive 7 cars. In the semi-digital gauges, the 4 plastic rings add a nice physical element to the display and the screens within them bleed behind the rings so you don't see the LCD border. It's cool how the physical ring extends into the digital part of the ring beneath the time, and the digital needle perfectly touches and lines up with the physical numbers. The black levels are also very good, so the fuel/temp needles on the left and right blend right into the black surround. You don't see any "screen" at all. The resolution is also very good and the graphics are excellent. It's very well integrated and designed and something I've never seen in another vehicle.
The iDrive 7 all-digital gauges, by contrast, sadly do not go all the way to the edge of the area, so you see this awful screen border on the left and right. The resolution also doesn't seem as good for some reason. Overall it just looks like a basic screen placed there vs. the cool, seamless look of the old gauges where the screen completely blends in and feels like a physical element. Last edited by bpu; 06-13-2020 at 12:18 AM.. |
06-13-2020, 02:12 AM | #2 |
2783
Rep 5,095
I've always wanted them to choose OLED instead of LCD for the displays, that way you have a true black background rather than the light leakage you get with LCD, most noticeable at night.
Whether its cost or technical issues as to why that's not been done to date don't know. I'm not a fan of the new display, I feel its a bit gimmicky. Whilst I believe they have redesigned the rev counter so they can fit in more information in between that and the speedo, I don't think is the right place for information, let alone detailed information.- at least when the car is moving. That information should be in the HUD, which is where your eyes are. Looking down to read information on the cluster means your attention is drawn away from the road. Whilst stationary, fair enough but not whilst on the move. I think there is still a place for analogue style instruments, in many ways they are quick to read. Analogue watches for instance are very quick to realise what the time is, you just "see it" rather than having to "read it" At the end of the day, BMW could technically offer us alternatives as to how the cluster is arranged whether that be a traditional analogue style or something gimmicky or something in between. No reason they couldn't offer something that looked like the E39 cluster for example. Whether they will is anyones guess. |
06-13-2020, 06:45 AM | #3 |
29
Rep 40
I've come from an M2 to a new G31 (I miss the M2!), so the dash was a big change for me. I've coded the G31 so the dash looks better (for me). It's also nice to be able to use the info screen for other things but still have the sat nav directions in front of you.
It's all about personal choice, but it's the way cars are going...more and more information in front of you...
2020 530d M Sport Touring, pretty standard but coded.
2018 M2, Met Grey, DCT, some options, and coded .... 2017 M140i, 2 door, Met Grey with red interior, a few options, and coded. |
IrishG30Guy20.00 |
06-13-2020, 08:12 AM | #4 |
794
Rep 661
I have a 2018 540 with the full digital dash and a 2019 X5 with the new digital dash. I strongly prefer the cluster on my 540. I think it just looks better in every way. I will be sorry to part with that and have to settle for the new dash on my replacement for the 540 when my lease is up later this year.
06-13-2020, 10:28 AM | #5 |
644
Rep 629
I have driven a couple of loaners with the newer gauges and I agree that I like the older G30 gauges much better. For one thing I am not used to a tachometer that turns counter clockwise and while I might get used to it, I don't care for it. That is different than any car I have ever owned and most all had tachometers. I also found I dislike the map in the middle between the tach and the speedo, I find it very distracting. Can that be turned off? Since it moves as the car drives it keeps catching my eye. I rarely need a map anyway. --Bob
2019 540xi M Sport, Carbon Black/Cognac, 2014 328xi, 2016 Corvette Z06; Previous:2010 BMW 535xi M Sp, 2008 335xi, 1998 M3 Sedan,1980 528i, 1977 320i, 1976 2002
06-13-2020, 01:00 PM | #6 | |
Tom W
135
Rep 194
Safe travels!
Tom 2003 E65 745i | 2011 F10 550i | 2021 G30 M550xi |
06-13-2020, 03:29 PM | #7 |
644
Rep 629
Thanks! At least one can turn it off. They need a command to turn the tach around in the right direction though.--Bob
bimmer_335177.00 |
06-14-2020, 04:41 AM | #8 | |
17
Rep 25
Current 2017 BMW 540i M-Sport Previous 2014 BMW 435 M-Sport Xi 2011 BMW 335Xi 2013 BMW X3 3.0s 2011 BMW 328 Xi |
06-14-2020, 04:28 PM | #9 |
58
Rep 39
I'm considering doing the same, could you let me know what all you've thought about it? Is buying it at lease end worse financially than if you bought it originally? Any concerns about warranty or maintenance?
06-14-2020, 04:39 PM | #10 |
3086
Rep 4,210
BMW's explanation for the backward tach makes no sense. It doesn't, as BMW has claimed, make more room for information in the middle of the display. Whether one runs the tach from top to bottom or bottom to top doesn't make for more or less room in the middle.
What gets me is that with a digital display, BMW could easily allow several different variants. Why it has chosen not to, especially when so many BMW loyalists dislike the new tach, is not understandable to me. |
bimmer_335177.00 Warp Ten643.50 |
06-14-2020, 05:02 PM | #11 | |
617
Rep 929
Thanks! |
06-15-2020, 03:09 PM | #12 |
29
Rep 40
I use "Bimmerlink" on a jail-breaked iPhone (version 13.5, not 13.51) running "CarBridge"
Alternatively, just use "Bimmerlink" displayed on the phone. You can display a lot of different parameters.
2018 M2, Met Grey, DCT, some options, and coded .... 2017 M140i, 2 door, Met Grey with red interior, a few options, and coded. Last edited by helidoc44; 06-15-2020 at 03:17 PM.. |
06-16-2020, 08:14 AM | #14 |
150
Rep 365
clearly unpopular opinion from me but I liked the original full LCD panel on the earlier G30's. I really like the new iD7 dials on my 2019 X5 and think that those semi digital dials on offer in early US cars was absolutely awful.
Each to their own I guess |
CosmicCharlie749.00 bastula183.00 |
06-16-2020, 10:13 AM | #15 |
3086
Rep 4,210
06-16-2020, 10:27 AM | #16 |
159
Rep 263
I don't like the old hybrid semi digital cluster at all.
It looks dated and actually is since it came out in 2014 on the 7 series. When I ordered my 2019 M550, I didn't realize that this was the standard instrument cluster for the US builds, so I changed the order and added the executive package in order to get the full digital display. I'm not a big fan of the newest display compared to the previous round dial full digital display, but still prefer it over the hybrid version. |
06-16-2020, 10:29 AM | #17 |
2458
Rep 2,714
I agree.The full digital gauges look fantastic in my wife’s 2018 540i.Especially in sport mode.BMW should just go back to this style when they do another redesign of the gauges.
530iDriver1707.50 |
06-16-2020, 07:58 PM | #18 |
790
Rep 997
I have the full digital gauges in our '19 G30. I think they were included in the Executive Package. I prefer them to the semi-digital ones in our '19 G30 X3. Both are nice, but the full digital is better aesthetically.
06-17-2020, 09:31 AM | #20 | |
644
Rep 629
06-19-2020, 05:12 AM | #21 |
38
Rep 162
I guess it is matter of preference. I much prefer the new digital gauges, and I really do not mind the reverse tacho.
If anything I much like the largish navigation map in between them. However, I would have expected some more customization |
Warp Ten643.50 |
