06-09-2020, 07:45 PM | #1 |
48
Rep 206
Right tune with xPH
I have JB4 locked in right now, i have MHD sitting behind. I don't want to put them on together, jm not knowledgeable in any of this. I like a daily driver that when i say go it goes, fast. That being said, im preparing to add the xHP flash on Friday. Ive been told two different things: don't run two different flashes together, they confuse each other; or it's ok, you can, each one is meant for two different things, they work independently. Im a bit confused and concerned here. I understand the maps of the car are the brains behind the power, you really shouldn't confuse it, alternatively, ive read jb4 can blow a motor; lets stay away from that. Ultimately, im not looking to go light to light looking for the next car to embarrass, im looking for my car to not embarrass itself.
Im going to upgrade the spark plugs n coils tomorrow, should hopefully fix the random between gear hiccups. At the end of the day, can i get some opinions or expert advise? This forum has been very helpful, i have learned a lot, im look forward to learning more!
2016 BMW 435i M-Sport
- JB4 and MHD - xHP - Injen intake - Active Autowerke intercooler - Active Autowerke charge pipe - AWE catback *** I want more!!!*** |
06-09-2020, 07:52 PM | #2 |
4368
Rep 7,616
Can you clarify your question? Are you asking if you can install XHP and run the JB4 at the same time? I am actually not 100% certain if there is any concern with flashing XHP while the JB4 is still installed. I would presume no, since XHP is a trans flash, but at the same time generally speaking you dont want to do any flash like MHD while the JB4 is still installed. Someone with JB4+XHP experience will need to confirm that, or you can email XHP or JB4 support to confirm (safest option).
You can definitely run XHP and MHD at the same time, that's the point really, and there is a option at flash time for MHD to "let the tune know" that you have XHP installed already. My advice, and the most conservative approach, is just remove the JB4 completely, make sure the car is running as it should without the JB4, then use that as a starting point to install XHP and then MHD as i mentioned in the other thread. Also, i don't know what you mean by "random between gear hiccups" but doing plugs and coils wouldnt be on the top of my list to address that. Plugs might be a good idea anyways before tuning depending on existing plugs and mileage. |
06-09-2020, 08:21 PM | #3 |
1086
Rep 2,361
xHP can be used independently of JB4 or MHD.
JB4 or MHD - choose one - that is the simple answer. I would strongly recommend MHD as mentioned before as you are not a DIY'er.
M135i 8AT PWG, MHD, Pure Stage2, WMI via Torqbyte CM5-LT, Custom tuned by PureBoost
(A Dane in China) |
06-09-2020, 08:39 PM | #4 | |
48
Rep 206
I would never run both tunes together. Im trying to determine which tune would be safely effective with a transmission flash. Im not really sure how to refer to it more than a hiccup. Occasionally, when my car shifts between gears i feel this hesitation. It feels like the acceleration pauses for a second and comes right back. It feels like my engine is beginning to disagree with jb4. I had springs installed today and i asked them to take it for a spin, he felt it too. He's felt the same thing with his car before, changed his spark plugs and coils and it disappeared. My car has 48000 miles, his belief is the engine is being introduced to so much more power with that amount of miles very suddenly. Im sorry if im unable to describe it well, please bear with me lol.
06-09-2020, 08:57 PM | #5 | |
1086
Rep 2,361
(A Dane in China) |
06-09-2020, 09:03 PM | #6 | ||
48
Rep 206
06-09-2020, 09:04 PM | #7 | ||
48
Rep 206
Blank
06-09-2020, 09:05 PM | #8 | ||
48
Rep 206
Blank
06-09-2020, 10:08 PM | #9 | |
4368
Rep 7,616
Given everything that's been discussed and your intent to switch to MHD anyways, my suggestion is exactly as i said out in the other thread. Remove the JB4, test drive the car and make sure its running properly, then proceed with XHP and MHD. If there are any issues with the car after the JB4 is removed, address those before tuning, as a tune will not fix mechanical or underlying issues. |
a404freedom47.50 |
06-10-2020, 11:01 AM | #10 |
Modder of everything I own
147
Rep 491
If you log your car you can provide the log for review by BMS support.
I run JB4 with MHD BEF with no issues and will be flashing xHP later this year as well.
2013 BMW 335xi F30 N55 PWG/VRSF DP/ER CP/Injen CAI/AA FMIC/JB4 map 7/Fuel= E50 w/ E85:93oct/Stock LPFP & HPFP/CATuned coilovers/Megan Racing Rear Swaybar/Powerflex Rear Subframe Bushing Inserts/Dual aFe Power Mach Force Mufflers/Resonator Delete/MHD & BMS Race BEF
06-15-2020, 11:41 AM | #11 |
BimmerPost Supporting Vendor
24317
Rep 191,028
I dont know if you can change the title or its too late, but it says XPH
a404freedom47.50 |
06-17-2020, 11:08 AM | #12 | |
4368
Rep 7,616
