Am I making this up?
06-09-2020, 02:51 AM | #1 |
3058
Rep 3,910
I seem to remember reading somewhere that CBU on the piston crown can build up to a level where it actually impacts the cylinder head, and causes knocking, etc? Is that true? How could I test it? Would it show up on a compression test?
I'm hearing a knocking noise from the engine when cold, at around 1200rpm, and only when cruising (30mph, 4th gear). It's quiet, and sounds fairly distant - I can only hear it when the road surface is smooth. It's definitely there, though. I don't think my engine is too worn. I don't get excessive blow-by or oil consumption, and no smoke at all. M57TU2 330d, 135k miles. 0w-30 castrol edge. Another potential cause might be a loose injector (not sealing to the cyl head properly)? There is maybe a slight tap on idle, but nothing offensive. Any ideas/suggestions beyond turning up the music? |
06-09-2020, 09:00 AM | #2 |
765
Rep 3,556
No direct experience here. Perhaps pull a glow plug and look down in at piston with a boroscope, if one will fit. I've never heard or read what you mention. Your 2nd hypothesis has a better chance of being true.
Tambohamilton3058.00 |
06-11-2020, 12:21 PM | #3 |
23
Rep 133
I have never heard of cbu on the piston. When I disassembled my engine the pistons were fine after 100k. I believe it gets too hot for CBU to build up in the combustion chamber.
As far as your noise, it could just be injectors. Or it could be something on the belt drive. Or maybe you or the previous owner didn't change oil often and the oil pump or passages are a little gummed up. |
06-11-2020, 04:43 PM | #4 |
3058
Rep 3,910
OK, cool. CBU on the piston is out!
Getting an oil analysis done next oil change ~end of the month, so we'll see if that highlights anything of note. Next time I have the engine cover off I'll check torques on the injector hold-downs, but I doubt that'll actually show any issues... I don't want to just tear into it and start replacing parts because it runs nicely as it is. Thanks guys |
