06-08-2020, 07:12 PM | #1 |
72
Rep 37
8 Series Eye Readers
I've seen in Non United States (go figure, strict US regulations..) BMW 8 Series have eye readers for the adaptive cruise control. My M850i has the readers as I'm sure all the 8 Series do, but they're turned off here in the US. I'm assuming it's a software block, so anyone know of a patch or loophole us owners in the US can get around?
06-09-2020, 09:05 PM | #2 | |
4292
Rep 4,360
Drives: 2020 M850i Coupe
I believe it should function the same way for the core adaptive cruise control if the car is not fully optioned with the Driving Assistance Pro package. However, in the US models the Driver's Attention camera may not exist with out the full boat package. |
AM850i72.00 |
06-10-2020, 04:01 AM | #3 |
6329
Rep 2,364
Drives: Z4 M40i
Only with Active Driving Assistant Pro (5AU)
iDrive - Car - Settings - General Settings - Driver Attention Camera - Activate/Deactivate [Z4=N/A ] Last edited by BMWGirlFL; 06-10-2020 at 04:12 AM.. |
06-10-2020, 07:08 AM | #4 | ||||
72
Rep 37
Yes, my 2019 First Edition has the Pro package. I've seen videos on YouTube where you can take your hands off the wheel and the system will stay active as long as you're looking at the road. I just tried it and the system shuts off after 25 seconds. I tried with the driver attention camera on and off. Both times the system deactivated after about 25 seconds. What's the point of the camera if the steering wheel needs pressure? (Luckily, I've noticed that just placing your knee on the wheel works to keep the system engaged.) |
06-10-2020, 09:59 AM | #5 |
769
Rep 554
IM'm pretty sure the driver attention camera's main function is to, basically, wake you up - i.e., keep you alert - under all conditions, not just if you have activated adaptive cruise control. In fact, I'm pretty sure it's not designed to allow you to keep your hands off the wheel during active cruise control.
- 2024 X6 40i, Carbon Black/Silverstone, M-Sport, Executive, DAPP, Climate, Air Suspension, etc. PCD.
- 2024 iX M60, Blue Ridge Mountain/Oyster, DAPP, Luxury Package. - Retired: Six previous BMWs. - Retired: Three Lexuses. |
06-10-2020, 10:32 AM | #6 |
6329
Rep 2,364
Drives: Z4 M40i
Camera Functional Description:
https://www.newtis.info/tisv2/a/en/g...tem/1VncmAbYWQ |
06-10-2020, 11:59 AM | #7 | |
769
Rep 554
“Unlimited driving up to 60 km/h without contact with the steering wheel when attentiveness is detected with the traffic jam assistant activated. The traffic jam assistant remains active if the driver looks at the road at specific intervals. The driver does not receive any request to touch the steering wheel.”
06-10-2020, 12:41 PM | #8 |
6329
Rep 2,364
Drives: Z4 M40i
Maybe?
Traffic Jam Assist: https://www.newtis.info/tisv2/a/en/g...ems/1VnXMZcV6k Read somewhere polarized sunglasses may create optical camera issue. Related: https://g05.bimmerpost.com/forums/sh....php?t=1656013 Last edited by BMWGirlFL; 06-10-2020 at 12:48 PM.. |
06-10-2020, 02:57 PM | #9 | ||
72
Rep 37
06-10-2020, 03:14 PM | #10 |
1292
Rep 1,658
I'm not sure this is what everyone is commenting about, but as an example our '17 Q7 has true semi autonomous driving for about +/- 20 secs where you do not need your hands on the wheel for that period and it even takes corners brilliantly even at highway speeds...
2019 M850i xDrive Coupe (06/19 Production)
Mineral White/Black, HP Cooling/Tire/M-Technology Pkg/Extended Shadow/Etc., Anthracite Headliner, Carbon Roof, DAx2, Display Key, Various Accs'. Topic permitting, I try to be objective as possible Last edited by RJC-1; 06-10-2020 at 05:17 PM.. |
06-10-2020, 03:15 PM | #11 |
6329
Rep 2,364
Drives: Z4 M40i
06-10-2020, 04:28 PM | #12 |
80
Rep 84
Drives: 2021 X5 40i, 2023 M3 Comp
Agreed - they describe the process correctly and it works the same in my 2019... If you reach the right conditions (<40mph, divided highway, etc) then a pop ups appears on the dash saying the Assisted Driving Plus is available. At that point you need to select that mode (by pressing Mode) - only then will you be in the"true" Assisted Driving Plus mode. This will disengage automatically if you go above 40mph... I have gone almost my whole 15 miles commute like that without touching the wheel...
BMWGirlFL6328.50 |
06-10-2020, 09:32 PM | #13 | |
4292
Rep 4,360
My commute when I had one (full WFH thanks to COVID-19) was primarily surface streets minus a short stint (~3 miles) on a divided highway. However, for the latter I tried to position myself in the turn lane to the on-ramp to frankly go into DILYSI mode and that continued on the highway until I exited. No assisted driving needed for that as it was balls to the wall, peddle to the metal or whatever colloquialism one chooses. It's why I bought the M850i in the first place. |
06-10-2020, 09:35 PM | #14 | |
4292
Rep 4,360
06-11-2020, 10:32 AM | #15 |
6329
Rep 2,364
Drives: Z4 M40i
06-14-2020, 09:44 PM | #16 | |
4292
Rep 4,360
06-15-2020, 04:39 PM | #17 |
1686
Rep 1,479
Drives: 2023 iX xDrive50
I also have to touch the steering wheel every 20ish seconds on my 2020. It's not any different than my 2018 M550i was in that respect. However, the 2020 M850i works much better at higher speeds and in turns. I just wish it did a better job at recognizing that I'm paying attention and wouldn't require the touch as often.
FWIW - I see the reference here to pressure on the wheel but unless I'm mistaken, the 8-Series steering wheel uses capacitive touch just like other BMW's. |
06-18-2020, 09:29 PM | #18 | |
4292
Rep 4,360
As for pressure on the wheel, although I generally keep at least my left hand on at all times under full Driving Assistance mode (still don't trust the car) you can just put pressure from a knee and it will do the trick. I'm heading out to San Diego tomorrow for a 6 day getaway with the wife and on the boring stretches of the highway I'll be in full Driving Assistance mode so can report back on if I can keep it engaged without at least a knee on the wheel. I doubt it based on experience to date, i.e., no pressure on the wheel and the little icon pops up with animation of placing your hands on the wheel. However, I've never let it go beyond yellow without complying so tomorrow I'll let it run at least one course (assuming red) and the disengagement of full Driving Assistance mode. Perhaps this is where the Driver's Attention camera comes into play and will over ride it. Update coming after some thorough testing on a 6 hour drive. |
06-23-2020, 11:57 PM | #19 | |
1604
Rep 2,937
Now it's flawless. |
06-24-2020, 09:56 PM | #20 |
4292
Rep 4,360
06-25-2020, 02:09 PM | #21 |
1686
Rep 1,479
06-25-2020, 04:23 PM | #22 | |
1604
Rep 2,937
If i ever update my software, I'll call him again to recode it. I'd prefer to have a few more options and a "lifetime subscription" but he was worth it. |
redhot47fla769.00 r33_RGSport12996.00 |
