Magnetic oil drain plug
06-05-2020, 10:41 PM | #1 |
11
Rep 133
hey guys has anyone switched out their oem oil drain plug for a magnetic one? I want to switch mine out but looking for recommendations. I heard the ecs tuning magnetic plug is no good and I'm currently looking at the mishimoto one from FCP Euro has anyone used that one before? if not what would you recommend?
06-06-2020, 02:52 AM | #2 |
354
Rep 511
Check these guys out
https://drainplugmagnets.com/ |
06-06-2020, 04:55 AM | #3 |
616
Rep 3,194
Drives: E92 325i MSport Coupe
Yep. I've replaced all my plugs with magnetic - engine sump, gearbox and diff. Mine were made in the US. Can't recall who. Can look it up if you need it.
E92 pre-LCI 325i - Ohlins R&T; H&R spacers; M3 strut brace; Swift thrust sheets; 3 x chassis braces; diff brace; N53 V-brace; 034 subframe inserts; BMS clutch stop; BMS CDV; RE g/box mounts; Delrin shift bushes; Saikoumichi OCC; Cyba scoops; BMW Perf Exhaust; HEL s/steel brake hoses; M3 rear spoiler; Recaro Sportster CSs; M3 white dash LEDs; LED Angels; LED side repeaters; BMW Perf black grille; CSL reps; SSDD carbon diffuser; Monster Wrap black roof/clear front
06-06-2020, 07:52 AM | #4 |
Just one more taste...
566
Rep 2,011
Just playing devils advocate here but what types of wear metals are you expecting to pick up with a magnetic drain plug? What parts of your engine would be likely to wear that would be picked up by it?
06-11-2020, 09:25 AM | #5 |
17317
Rep 18,740
06-20-2020, 10:28 AM | #6 |
Slow.
3782
Rep 7,151
Drives: Single Turbo N54 on Meth!
Better off doing a blackstone oil analysis(or whomever you prefer) every oil change if you want to learn about the condition of your engine. They are inexpensive enough and potentially informative.
Magnetic oil drain plugs are a bit silly and I would consider a waste of money. But they are cheap, if it makes you sleep better at night get one.
b1aze565.50 |
06-20-2020, 10:34 AM | #7 |
23
Rep 32
I have replaced my engune oil drain plug with one of these https://www.stahlbus.com/info/en/pro...l-drain-valves
06-22-2020, 05:01 AM | #9 |
102
Rep 681
Got a mate with an n52 which for the last 30k miles has shown little metal bits in the oil filter. No idea whats causing it, engine runs and sounds fine. Unless you cut open the filter you'd never know they were there. A magnet wont pick them up because they are aluminium - like most of the engine.
06-22-2020, 03:12 PM | #10 |
E82 Mudflap Ambassador
2214
Rep 2,219
Drives: '08 128i
Yeah the motor is mostly aluminum and magnesium. You won't be picking much up.
Get an oil analysis done.
My 2008 128i - Sparkling Graphite/Beige - Sport pkg - 6MT - Click me!
Parents' 2014 528i - Mineral White/Ivory White - fully loaded Instagram @Andreys_128i and @Honda.Bito |
06-22-2020, 10:29 PM | #11 |
626
Rep 2,099
If you really want one, Dimple makes a good one, and I think ECS had a decent one too. Changing out your oil at the proper interval is a better plan though.
06-23-2020, 11:25 AM | #12 |
705
Rep 2,605
Drives: 06 330i E90, 18 530xe G30
I bought a ECS one for no other reason than I was curious and was paying for shipping already for some other parts and impulsively got it. I've probably done about 5 changes since and every time there is a VERY slight buildup of metal "dust" on the magnet. Nothing that makes me believe in the concept to be honest.
PhaseP1007.00 |
06-25-2020, 02:27 PM | #13 |
3973
Rep 7,215
I mean, think about it - if the magnet is picking up anything significant due to metal on metal wear, the damage is already done and your engine is probably toast.
