M5POST
Go Back   M5POST - BMW M5 Forum > F10 M5 Forum > F10 M5 DIY Guides
      06-05-2020, 08:41 AM   #1
vafan13
295
Drives: Sakhir Orange F10 M5
monoball install DIY - can someone translate?
Reading through the newtis for the thrust arm to determine whether I'm comfortable doing my monoball install DIY and it all looks pretty clear cut except for #2 under "installing trailing link" at the end. Can anyone translate this to mechanically-inclined-but-not-a-mechanic?
Also, I remember reading somewhere that monoballs don't require suspension load before tightening, unlike the stock bushings. Is that accurate?
Risk of damage!
Observe assembly sequence.
Trailing link must be screwed in normal position!
(Adjustment of normal position, see below).
Installing trailing link:
1. Install trailing link on front axle support (do not tighten down screw connection).
2. Adjust the trailing link with the swivel bearing for dimension (A).
Dimension (A) = 2 cm (vehicle on vehicle hoist, spring strut rebounded)
Note: Installing the trailing link to dimension (A) corresponds to the normal position in the compressed state!
3. Tighten tension strut at the front axle support.
Tightening torque 31 12 1AZ.
4. Press trailing link into swivel bearing and tighten trailing link/swivel bearing.
Tightening torque 31 12 2AZ.
      06-12-2020, 01:05 PM   #2
vafan13
295
as an FYI in case others are confused by this in the future, I believe I have cracked it. The goal of step 2 in that section is to have the arm at the correct angle when torqueing the bushing bolt at the chassis (step 3). Basically, it's trying to mimic the angle the arm would be at when the suspension is loaded without having to load it.
      07-26-2020, 04:35 PM   #3
vafan13
295
As another update: the nut one connects the thrust arm to the hub with is conveniently 2cm. As such, one can put this nut on the hub and rest the swivel bearing lug (or whatever) on it to keep the 2cm while tightening the bolt on the chassis.
I will say that getting either the bolt or nut to the proper torque spec was very hard. Even with a longer torque wrench we didn't quite get there. Close, but not quite there.
      11-06-2020, 04:19 AM   #4
Elizabeth22
Drives: BMW X5
Anyone looking to place the best bets on https://beatingonlinecasino.info/ric...-slot-machine/ has the best site as a great tool to help them win. Determine the best betting odds and compare them to maximize your profits and chances of winning.
m5post
