06-02-2020, 11:24 PM | #1 |
95
Rep 430
I know that X7s have built in antitheft alarm systems built into them but I have never had them working on mine. Probably I might have some sensors/features disabled or not properly set?
Here is what I have experienced most of the times; 1. I leave the car unlocked (engine off), Key fobs far away from the range of the car in a parking lot. Leave the car like that parked for over 20 minutes. I reach back out to the car (of course without the key fobs AND my Phone with me) and open the driver side door sit inside the car for a while, touch the interface buttons etc. and no any kind of panic alarms sound!! Situation #2: Leave the car unlocked for a while and everything else explained as above in #1 above, I shake the car hard enough from the outside (pretending that any gyroscopic/motion sensors would come into play and the car would sound the alarms but nothing happens!! Anyone else encountered it? Am I doing something wrong here? I feel like if I forget to lock the car someone can easily break in and do something. Edit: sorry guys I didn't realize that the anti theft systems come into action when the car is locked. I kinda feel shy Last edited by FreddyBMW; 06-02-2020 at 11:30 PM.. |
06-03-2020, 12:10 AM | #2 |
11
Rep 19
Maybe the problem is the fact that you didn’t lock the car... try to lock it an grab through the open window...
FreddyBMW94.50 unfoundnemo1909.00 |
06-03-2020, 09:49 AM | #4 |
///M SubDriver
1837
Rep 2,783
Drives: 2017 M3, 2020 X7 40i
Are you saying that the Drive Recorder will trigger an "event" when the alarm system is triggered while parked? Or are you referring to the security cameras around your building/parking lot...?
///M3 COMPETITION 6MT - 2017 F80 Smoked Topaz Metallic
BM3 / MP-HAS / GC Camber Plates / Carbonstructure Interior X7 XDrive 40i ///M-SPORT - 2020 G07 Arctic Grey Metallic X3 XDrive 30i - 2019 G01 Mineral White (wife's) / 128i 6MT - 2009 E82 Jet Black (son's) |
06-03-2020, 06:30 PM | #5 |
674
Rep 1,021
My alarm went off the other day and I couldn't figure out what the heck set it off. After closer inspection, I realized that my radar detector's suction attachment had released and it fell into the passengers seat. Guess it works
06-03-2020, 06:35 PM | #6 |
95
Rep 430
Can't wait anymore to see that "sentry mode" of Tesla on the X7. They have all the hardware that those Teslas have.
I guess BMW needs a serious software team that know how to code things.
2019 X7 40i Metallic Black
06-03-2020, 10:13 PM | #7 | |
116
Rep 258
CCTV cameras on my storefront office. Not the drive recorder. |
06-09-2022, 05:16 AM | #8 |
Rep 1
Well, if you are often put your car in the garage you can try to forget about these issues and install the proper security system, so you will need to think about locking your car because car will be inside of the additional security system, personally, i don't lock my car ever after I park car in the garage. I use this professioanl service as my main security system contractor, https://wyesecuritysolutions.co.uk/ maybe it will be useful in your situation.
06-09-2022, 09:58 AM | #9 | |
639
Rep 1,588
Sentry mode uses a lot of power. Tesla has a huge battery pack to power it. X7 does not. |
06-09-2022, 10:54 AM | #10 |
28
Rep 62
Drives: '19 X5 40i, '22 X7 M50i
Alarm must be armed
It is my understanding that the alarm system must be armed (turned on) to monitor the vehicle, and that is accomplished by locking the car.
Apparently, even with the Tesla Sentry mode, you have to turn it on. Otherwise it would be a giant hassle setting off the alarm more often than necessary with any activity involving the vehicle at any time. When we get to mind control of the cars, that will help!!! |
06-09-2022, 03:53 PM | #11 |
73
Rep 171
That's true. Sentry mode in my Tesla uses around 2% of the battery per hour! Without Sentry mode, the usual drain is 1-2% a day.
06-10-2022, 07:40 AM | #12 |
1909
Rep 2,007
Drives: 2022 i4 M50
I know if I wear skinny jeans and shift my weight the right way with my fob in my pocket the panic alarm will go off.
Current: 2022 i4 M50 | 2022 G07 X7
Gone: 2020 F92 M8 | 2020 G07 X7 | 2018 F80 M3 | 2017 F15 X5 | 2016 F16 X6 | 2015 F36 4 series GC Last edited by unfoundnemo; 06-10-2022 at 11:18 AM.. Reason: typo |
06-10-2022, 10:22 AM | #13 |
28
Rep 62
TMI!
06-10-2022, 04:45 PM | #14 |
4448
Rep 7,488
Is it really considered a “break-in” if the vehicle is UNLOCKED?
FYI…unless BMW changed things with the X7…the IMS (interior motion sensor) & TILT sensors have a delayed activation of approx 20 seconds. So if you want to test them…you would need to roll a window down…lock the vehicle…then wait approx 20 seconds…then stick your arm inside the cabin and wave it around. The siren should sound off. Same with the tilt sensor…it takes 20 seconds AFTER locking the vehicle. You can also press the button on the remote to activate the PANIC alarm. This should be covered in your owners manual on how to activate it. If you don’t have the physical manual…there’s one built into iDrive (which also has a search feature). Just type “ALARM” into the search field.
2015 F06 650ix Gran Coupe`(Moonstone/Cohiba Brown)| 2014 F15 X5 50i MSport (Space Gray/Mocha)
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. |
