BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > NA Engine (non-turbo) / Drivetrain / Exhaust Modifications > P1624 P110D Limp Mode 2006 330i
      06-02-2020, 07:48 PM   #1
blackedout330i
Drives: 2006 330i
Question P1624 P110D Limp Mode 2006 330i
After fixing some issues I am getting a P1624 error. It puts the car into limp mode and I cant accelerate much at all. If I shut the car down and restart it works just fine. The two codes is threw was
P110D
P1624
Any help on how to diagnose this issue? From what I've searched it could be either a thermostat issue or pedal controller?
      06-02-2020, 10:24 PM   #2
hassmaschine
3973
Drives: "NBO" 330i
P-codes mean nothing to me. Got a BMW scanner?
      06-03-2020, 01:47 PM   #3
blackedout330i
Drives: 2006 330i
hassmaschine I'm working on getting INPA to work but I cant get it to load yet/connect. Comes up with that error 18 code. Working more on it today just hot as balls sitting in a car in a garage in 90deg weather lol
      06-04-2020, 03:57 PM   #4
E92William
1998
Drives: 2008 E92 328xi
2008 BMW 328xi  [0.00]
You're gonna want to scan this with a proper scanner. As of now I'd be more inclined to say it's a pedal issue but who knows if it's a valvetronic issue and it's throwing a code for the throttle because that's what it's using as a backup. The valvetronic goes full lift and shuts down if it has a fault, so your engine speed will be controlled by the tb.
      06-04-2020, 08:34 PM   #5
PhaseP
1007
Drives: 325XI
P110D
P1624
What were the issues you fixed? Did they involve removing throttle body electrical connector under intake manifold, or anything to do with gas pedal wiring or harness?
First code says throttle body sensor, 2nd code says gas pedal sensor supply (electrical I suppose) From Bentley manual.
