Swapped coil and spark plug seperately still same misfire p0305 code
05-31-2020, 07:54 PM | #1 |
11
Rep 85
N51 engine with p0305 cylinder 5 misfire. Swapped coil first with cylinder 2 cleared code same code came back after second start. Swapped plug to cylinder 2 cleared code...same code came back as well. Any ideas what to do next...injector swap? Car runs fine btw
06-01-2020, 01:35 PM | #3 |
616
Rep 3,194
Drives: E92 325i MSport Coupe
Then I would guess an injector is leaking overnight, leading to a misfire first thing in the morning until the excess fuel has burnt off.
E92 pre-LCI 325i - Ohlins R&T; H&R spacers; M3 strut brace; Swift thrust sheets; 3 x chassis braces; diff brace; N53 V-brace; 034 subframe inserts; BMS clutch stop; BMS CDV; RE g/box mounts; Delrin shift bushes; Saikoumichi OCC; Cyba scoops; BMW Perf Exhaust; HEL s/steel brake hoses; M3 rear spoiler; Recaro Sportster CSs; M3 white dash LEDs; LED Angels; LED side repeaters; BMW Perf black grille; CSL reps; SSDD carbon diffuser; Monster Wrap black roof/clear front
06-01-2020, 05:34 PM | #4 |
11
Rep 85
Thanks for that I was thinking the same I'm going to swap injectors as my next step. I went ahead and cleaned off the nearby ground strap next to the 5 coil there was some build up
06-01-2020, 08:28 PM | #5 |
11
Rep 85
06-04-2020, 04:00 PM | #6 |
1998
Rep 2,026
Drives: 2008 E92 328xi
Swap the injectors it's quite easy. If it isn't that it could be some vacuum leak that goes away when the engine gets warm or who knows. Any other codes that aren't P codes? Aka Bmw specific ones
06-05-2020, 04:11 PM | #7 |
11
Rep 85
Thx for response going to swap injectors this weekend any tips? No other codes I clear after I do a change nothing else comes up. How do injectors get leaky?
06-05-2020, 10:18 PM | #8 |
11
Rep 85
Ok swapped an injector with a spare from a buddy keep your fingers crossed for me... hardest part was keeping all the fine debris and dirt from falling into the engine head when removing the injector rail
06-06-2020, 01:43 AM | #9 |
1998
Rep 2,026
Fingers crossed it's that though n52 injectors aren't usually a problem
