Studio RSR
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > MHD Boost Reading
      05-30-2020, 07:35 PM   #1
beamerboi1120
Drives: 2009 335xi
MHD Boost Reading
I just flashed stage 2+ on my 335xi. This is my first N54 so sorry if I my questions are dumb. I'm going through my boost psi gauge and at idle I'm about -9 to -11. Then the max is 9 boost psi when I get on the throttle. Then I switched over to the boost target psi where I'm hitting 16-18 psi when I get on it. Are my numbers looking low? And which boost gauge should I look at? Btw I have no codes or shadow codes.
      05-30-2020, 07:47 PM   #2
Saif2018
973
Drives: E90 335i
Post a log.
The negative numbers off throttle is normal.
Target PSI is what your tune is trying to hit. We need a log to see actual psi and wether your turbos are struggling or not, or other issues present.
      05-31-2020, 07:20 PM   #3
Smgs1992
721
Drives: 2007 bmw 335i
If you're only hitting 9psi when targeting 18psi (which stage 2+ should be) then you likely have a boost leak or bad boost solenoids or vacuum lines. Check your chargepipe and intercooler connections. Then I'd check your vacuum lines.
I had bad boost solenoids but I would underboost and overboost.
As stated it your turbos have high mileage they might not be capable of reaching target boost but I'd imagine you have a boost leak somewhere. Post logs first.
07 E92 335i 6MT, MMP inlets, DCI, VRSF 7.5 competition intercooler, VRSF catless downpipes, VRSF chargepipe, 335is clutch, Vader Solutions stage 2 LPFP, MHD stage 2+, Hawk HPS 5.0 pads, R1 Concepts drilled slotted rotors, TSW Nurburgring 19x8 19x9.5
      06-01-2020, 01:23 AM   #4
borskii
15
Drives: 335is 6MT
Negative boost while not on throttle is normal. 9 psi on target of 18 is low, so as other have mentioned definitely post logs. Should usually be no less that 2 psi under target.
Also, I don't mean this as any insult, but since these are fairy beginner questions, I'm little concerned that you have a stage 2+ flash already. Did you already do supporting mods (FMIC, DP, CP, maintenance, healthy coils/spark plugs)?
      06-01-2020, 10:25 AM   #5
Bimmer_Engineer
Bimmer_Engineer's Avatar
1044
Drives: 2007 335i
Are you getting a 30FF when yo got WOT? If you're 9 psi below target it should be throwing a code...
      06-01-2020, 07:35 PM   #6
beamerboi1120
Drives: 2009 335xi
Yeah I'll try to get a log soon. Yeah the only reason I went stage 2+ is because its FBO, oil just got changed aswell as coils and plugs, and I'm running index 12's. I appreciate the concern though.
      06-01-2020, 07:37 PM   #7
beamerboi1120
Drives: 2009 335xi
Yeah no codes. I was before, I believe one of the hoses to my bob was loose but I haven't gotten a code since
      06-01-2020, 11:20 PM   #8
borskii
15
Drives: 335is 6MT
View post on imgur.com
Nice, well looks like you have your ducks in a row.
Sample boost log from 3rd gear pull. Granted I'm on a Dinan S2 w/ stock DP's.
      06-02-2020, 03:40 AM   #9
Saif2018
973
Drives: E90 335i
Agreed, op needs to eliminate any possibilities of boost leaks first, all vacumn lines need to be replaced if not done recently , boost solenoids need to be checked and replaced if needed, chargpipe/connections etc.
      06-05-2020, 06:24 PM   #10
beamerboi1120
Drives: 2009 335xi
Here's the log
https://datazap.me/u/sergio/mhd-s2-j...&data=3-22
      06-05-2020, 06:28 PM   #11
beamerboi1120
Drives: 2009 335xi
Here's the log
      06-06-2020, 12:22 PM   #12
Jerain
Jerain's Avatar
72
Drives: E92 335i 6MT
For sure boost leak/vaccuum problems...
____________________________________________
2007 BMW E92 335i 6MT lightweight - OS GIKEN Superlock LSD - FBO STAGE 2+ ETHANOL - TRACK/DRIFT/NÜRBURGRING
