BMW 5-Series (G30) Forum DIY Discussions / Guides / Instructions Need help coding new headlight
      05-29-2020, 08:15 AM   #1
nickf1224
Drives: BMW 540xi
I just brought a new headlight and it came with modules. I need it coded to the car. It comes on and then blinks off . I have no knowledge or coding at all . And I don't know what tools I will need . I do have a MacBook and I have a Bluetooth obd2 plug. Not sure if it helps but I do indeed need help. Thanks
      08-04-2020, 03:42 PM   #2
David MK
Drives: Bmw G30 2020
I have going through the same situation that you have, what I think you need to have ENET cable and download 3 software )ESYS and another 2
Then you will be able to have a remote coding service
If already fix that pls share you experience with me since i am still searching
      08-16-2020, 05:58 PM   #3
Zeezu541
21
Drives: F20 M140i || M3 F80|| F90 M5
Hi mate I believe you just need to select the cafd and code it
      10-09-2020, 03:11 PM   #4
xxxjecxxx2
xxxjecxxx2's Avatar
153
Drives: F30 335i M Sport
2013 F30 335i  [0.00]
2015 F15 X5  [0.00]
2017 G30 540i  [0.00]
Esys may not be enough.
Because when a new headlight is installed or some of the other components. You also need to run a learn in procedure in ISTA for the LED bulbs.
      10-09-2020, 03:33 PM   #5
Zeezu541
21
I've just programmed a headlight through esys I can confirm you just select cafd and hit code
5post
