E92 335d oil leak above charge pipe
05-27-2020, 09:29 AM | #1 |
Rep 4
Could anybody help advise which part is leaking oil here and what the part number should be? 2007 e92 335d. The red charge pipe was covered in oil and I have just replaced but this seems to be the source.
05-27-2020, 07:44 PM | #2 |
1231
Rep 1,101
Whatever is leaking, it looks like it has been doing so for a long time. Its probably best to clean up the area first and periodically check to see where the oil starts appearing. That would be the easiest way of determining whats leaking. You'll have to do this anyway if you install any new parts and want to make sure the issue is rectified.
That being said, you could probably start with replacing the turbo oil line (11427795971) and the CCV hose. Both are common failure points on the engine. The CCV hose probably isnt causing the oil build up on the top of the engine, but it could very well have been partially (or completely) to blame for the oil you cleaned up off of the red charge pipe. As far as I am aware, AARodriguez is the only vendor who sells the rubber CCV hose separately (https://www.tunemyeuro.com/ccv-hose-...-335d-aar2238/). If purchasing from him is not an option, you can always purchase the whole assembly at your local dealer or favorite local parts distributor/vendor (part# 13717808158), albeit at a much greater cost. How many miles on your car/engine? |
Ra5cal1.50 |
05-28-2020, 09:14 AM | #3 | |
Rep 4
05-28-2020, 09:30 AM | #4 | |
1231
Rep 1,101
AARodriguez has a 100k mile service kit that seems to include a lot of the commonly failed parts on these engines. I'd consider looking over whats included in that kit to get an idea of what to replace to prevent issues down the line. Heres a link to that kit: https://www.tunemyeuro.com/100k-rest...-for-bmw-335d/. I wouldn't be surprised if other vendors had similar kits available. If you intend on keeping the car for a while, take a look at the North American Diesel Owners Group on facebook. A lot of the former members of this forum have migrated over there and seem to be very active there. |
Ra5cal1.50 |
05-28-2020, 12:23 PM | #6 |
5483
Rep 5,421
Drives: Beige G31 40ix m sport
Oil filler cap can also let a bit of oil by & I suspect a lot of it is from spillage during oil changes/top ups.
It is diesel.....it's always going to be oily & smelly
G31 40ix M Sport
E92 335i. E36 328is coupe E39 540i V8 6SP manual E34 3.6 M5. E34 525i sport. VW Jetta Mk2 GTI 16v. 1679cc 1967 resto-cal beetle |
Ra5cal1.50 |
05-28-2020, 04:21 PM | #7 |
Rep 4
Lol true
Chappers 715483.00 |
05-29-2020, 08:15 AM | #9 |
1231
Rep 1,101
05-29-2020, 04:17 PM | #10 |
5483
Rep 5,421
Just smelly then
G31 40ix M Sport
apexit41230.50 |
