FS: ZSP Sport Suspension Including the ZSP Rear Sway Bar!!
09-19-2008, 03:56 PM | #1 |
Modder Raider
758
Rep 8,633
Drives: M3
SOLD I am selling everything you need except for the Springs. I repeat, I am not selling the springs. I'm sure that these sport dampers will work great with many springs including the Eibach sport, H&R sport springs, and of course, the OEM sport package springs. As you can see in the picture, you will get everything you need including spring bushings, and bumper stops. I even have extra bolts and nuts but you will most likely use the ones you already have. They're included just in case though. I think that $240 is a fare price for this, but offers are welcomed. Thanks for looking!
e36 M3 Coupe, e36 325i Sedan
e90 335i--SOLD Best 60-130-------------9.15 Seconds------------------WWW.MR5RACING.COM |
09-23-2008, 03:08 PM | #3 |
Modder Raider
758
Rep 8,633
Drives: M3
I don't think so.
This combo is perfect for someone wanting to upgrade. And, after doing the installation myself, if you are going to do the sway, you might as well install the springs and shocks at the same time.
09-25-2008, 02:59 AM | #4 |
Amateur Post Whore
117
Rep 3,036
Drives: 07 E90 SparkLiN G. 335i
AHHH...... so tempting.. I have non-sport suspension right now, if I transfer my springs over to your sport suspension, would the height be decreased??
Go WiTh ThE FLoW.
|BL|RS|PIAA|CFE|CFMC|SSM|CFG|CFDP|ABG|M6|AFE|MTECH |RPI|JB+|CSLT|KWSC| |
09-25-2008, 08:24 AM | #5 | |
Modder Raider
758
Rep 8,633
Drives: M3
Usually, the ride height is determined by the springs. Seriously though, get a set of springs to go along with this setup and you'll be styling!
09-26-2008, 09:52 PM | #7 |
Modder Raider
758
Rep 8,633
Drives: M3
My odometer said close to 22k when I changed them out, and I don't know if there's a difference between freeway miles and city street miles or not, but just to let you know, I'd say that about 20k miles are Orange County Freeway miles.
09-30-2008, 10:55 PM | #9 |
Modder Raider
758
Rep 8,633
Drives: M3
yup
10-15-2008, 02:52 PM | #11 |
Modder Raider
758
Rep 8,633
Drives: M3
bump it.
11-06-2008, 04:12 PM | #12 |
665
Rep 26,878
Drives: 2-325 330 2-335 2-Z4 2-135 X5d
I'm interested in these for my gfs non-ZSP E90.
I would get some Eibach sports or something similar of course to drop it but. . . How are these shocks and struts different from the non ZSP? I thought it was just the different ride height from the ZSP springs that was different. Also, how hard is it to swap out the E90 suspension? |
11-08-2008, 07:21 PM | #13 |
665
Rep 26,878
for my question
11-10-2008, 09:35 PM | #14 | |
Modder Raider
758
Rep 8,633
Drives: M3
The dampers are easy to change out but the rear sway is a pita. These dampers are definitely stiffer than the normal suspension. Ride height is only determined by the springs. Again, the normal dampers are much softer than these.
11-10-2008, 10:18 PM | #15 |
Amateur Post Whore
117
Rep 3,036
Stiffer? You mean you can feel more bumps on the road compared to normal OEM suspension?
Go WiTh ThE FLoW.
