Bimmerpost
4 Series
Technical Topics DIYs and Coding Discussions I added Equalizer Settings on my G20
      05-23-2020, 12:56 PM   #1
Guns N Roses
GUNS N ROSES
18
Drives: BMW 330i 2019
Finally after a lot of try and error here is my first post and contribution to this forum after I purchased my g20 last year I noticed the lack of equalizer settings on my Base 330i I was thinking no problem I can add one WRONG ! Well after going to numerous places getting quotes and getting non sense amounts from 2k to 4K you can do it because of the ram radio thanks to bimmercode and research on expert mode here is the procedure go to bimmercode to HU MGU HEADUNIT then expert mode from there pic 3002 then look for AUDIO-SYSTEM then change the parameters from alev2-Ram to alev4-Ram code and you got a free working Bowersand Wilkins settings and working equalizer enjoy,
Appreciate 8
greekcs773.00
EXE462100.00
VipinLJ1941.50
pneumodoc233.00
      05-23-2020, 01:02 PM   #2
chenry
2358
Drives: BMWs
And this my friends is one hell of a first post. Welcome and thanks for sharing!!
      05-23-2020, 01:02 PM   #3
greekcs
greekcs's Avatar
773
Drives: 2020 M340i xDrive
Nice find!
2003 11/02 Steel Gray Metallic on Red M3 - SMGII - VF570 - SUPERSPRINT - KW - BBS - CSL ROOF SOLD
2015 09/14 Alpine White on Red 435i xDrive MPPK - Expensive black vinyl with special lettering. SOLD
2020 12/19 Mineral Gray Metallic on Black Vinyl interior M340i xDrive
      05-23-2020, 06:18 PM   #4
mlavio829
Drives: 2020 BMW 330i X Drive
Awesome find!
      05-24-2020, 09:21 PM   #5
mlavio829
Does it significantly improve the quality of the stock system?
      05-24-2020, 10:25 PM   #6
pneumodoc
pneumodoc's Avatar
233
Drives: G20, G01
I’m wondering if anyone has some good EQ settings to consider.
      05-25-2020, 07:24 AM   #7
MY86
MY86's Avatar
Turkey
15
Drives: G30 520i G20 320i
Does it make any difference on stock stereo systems? I don't have Hi-Fi or Harman Kardon Surround.
      05-25-2020, 09:39 AM   #8
sztmek
21
Drives: BMW 3 G20
I dont know how this feature has influence for stock Audio system , but bower Wilkins settting in “ concert” change my audio settings to different level. Bass and treble are much much higher, sounds magic. Of course I added eq settings like V sounds and increased surround level to max.
      05-25-2020, 12:08 PM   #9
MY86
MY86's Avatar
Turkey
15
What you got? Hi-Fi or HK ?
EQ settings seems to be working pretty good on stock system.
I wasn't expecting anything from the sound profiles since I have the stock system.
      05-25-2020, 12:47 PM   #10
hottroc
45
Drives: BMW 330e
That's awesome work mate. So on the stock system does it actually work as an equaliser, with adjustable bands, or is it just cosmetic? Please tell us more.
      05-25-2020, 12:57 PM   #11
sztmek
21
Drives: BMW 3 G20
Yes i have harman kardon audio. The surround settings is much much better so now I feel voice of singer completely different as on the stage .
      05-26-2020, 11:11 PM   #12
imported_nick
81
Drives:
How the heck did you get Expert Mode on HU_MGU?
      05-27-2020, 06:07 AM   #13
MY86
MY86's Avatar
Turkey
15
E-mail to owner in order to get the beta version from the Test Flight
support@bimmercode.app
Somebody correct me if the email is wrong.
      05-27-2020, 12:33 PM   #14
PersonaNonGrata
PersonaNonGrata's Avatar
83
Drives: 2020 M340i
Welcome! Outstanding post and a doozy for your first one! I’m going to have to try coding this too.
      05-27-2020, 01:06 PM   #15
pneumodoc
pneumodoc's Avatar
233
Drives: G20, G01
I contacted bavsound (since I have stage 1 plus ghost woofers) and they suggested the following settings. I don’t have logic 7 as an option, but will try the rest.
Bass - FLAT
Treb - FLAT
Logic 7 - ON
Balance FLAT
Fader FLAT
(keeping it flat after speakers break in give you the best reproduction of the music, although I did have it "+1 Fader" originally to create more imaging while keeping the volume down)
+2 100HZ
-3 200HZ
-1 500HZ
-3 1KHZ
-1 2KHZ
-2 5KHZ
-1 10KHZ
Appreciate 2
greekcs773.00
RSnic657.50
      05-28-2020, 07:43 PM   #16
Guns N Roses
GUNS N ROSES
18
About the settings on my G20
Yes I also have aftermarket speakers bavsound (the best ) and I am glad that they share some settings for this mod already added a aftermarket JL AUDIO WOOFER mono to the 2 woofers in the bottom of the seats and let me tell you I used to sound really flat only using the treble bass and fader lol I know it’s sad but I been playing with it a bit and it’s sound amazing so I can really tell that the mod it’s not just (cosmetic) there is a setting to make it louder on expert since the number set on Max Vol ( in German ) it’s set on 35 I may play with it a bit this weekend it will be my next frontier 😁 since bavsound had not released a amp for us yet
      05-28-2020, 07:46 PM   #17
VipinLJ
Petrolhead
VipinLJ's Avatar
1942
Drives: ‘20 330i,‘16 X3,‘18 SQ5,‘17 A7
I tried it on the non-HK HiFi system in my car and couldn't notice a difference with the presets (movie theatre, concert etc). With the equalizer, I noticed a difference only when I changed the two on the ends (bass and treble settings) and none in the middle (100Hz, 200, 500 etc). I tested it on SiriusXM.
Current:
2020 BMW 330i xDrive
2018 Audi SQ5 Prestige
2017 Audi A7 Prestige
      06-04-2020, 09:15 AM   #18
hottroc
45
Drives: BMW 330e
Thanks for testing. So it IS just cosmetic on the stock system then ie if your hardware doesn't support it...so you may as well just stick with Bass and Treble.
      06-04-2020, 11:24 AM   #19
Ventura24G20
Ventura24G20's Avatar
No_Country
12
Drives: 23 BMW G80 M3
Do you have to delete the original Bimmercode app to use the beta mode?
      06-04-2020, 02:35 PM   #20
MY86
MY86's Avatar
Turkey
15
No. You don't have to do that.
      06-04-2020, 02:40 PM   #21
Ventura24G20
No_Country
12
so i can use both without any issues correct?
      06-04-2020, 07:54 PM   #22
VipinLJ
Petrolhead
VipinLJ's Avatar
1942
From how it works in my car, yes. It's purely cosmetic. I totally forgot that I had coded that. I'll revert it back to stock.
Current:
g20
