F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N20, N26, B46, B48 Turbo Engine / Drivetrain / Exhaust Modifications > F33 N20 428i AT Rough idle really worried...
proTUNING Freaks
      05-17-2020, 09:49 PM   #1
bmwaddictt
bmwaddictt's Avatar
Australia
57
Drives: M4 6 Spd, X6 G06 30d, G22 420i
Question
Hi everyone, hope you are all keeping safe during these difficult times.
My 428i idle's very very rough, almost like its about to stall. I'll give a little back story. I've been running Bootmod3 Stage 1 93oct for almost 10,000kms now all stock and around 5000kms with a catless downpipe and everything was working and driving like a charm. The car then was due for a major service at 65,000 kms with spark plugs oil change etc all required, everything was allgood till the car came up and eventually popped up with 'overdue 500kms' and i started the car one day and it was like it was about to stall. This happens everytime i come to a red light as well and go to a full stop, car is about to switch off, rpms are very rough. I took the car into BMW my service advisor told me that I did not need to remove the tune so I did not. They serviced the car but they didn't see anything wrong with the idle. Stupid if you ask me. As soon as I jumped back in the car started it, immediately I realised... Very stuttery rough start, and if you just tap the accelerator pedal a little and let go the car is almost about to turn off. What could be the issue? There is no codes that come up, but sometimes a transmission ESG error comes up code CF1531 when the vehicle is switched off after a tune update idk if thats normal. I'm really worried. Even flashed it back to stock, still the same problem... Please someone help!! Thank you
Edit: guys could this be an engine knock?? Please see video
~ Sapphire Black M4 G82 Manual
~ Mineral White Metallic X6 G06 30d M Sport
~ Sapphire Black 420i G22 M Sport
#savethemanuals
      05-17-2020, 10:35 PM   #2
muniz_ri
448
Drives: BMW 320I
I would start by checking the spark plug gap. Improperly gapped plugs will cause a rough idle...not to the extreme that you described but still worth checking.
      05-17-2020, 10:37 PM   #3
bmwaddictt
bmwaddictt's Avatar
Australia
57
Hmm right I'll get this checked. By the way, when changing the Downpipe, does the 02 sensor need to always stay disconnected? I think my mechanic did not remove these. The car has been fine ever since the service light came on at 500kms though?
#savethemanuals
Tags
n20, rough idle, rough start, roughidle
f30post
