Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N57 / M57 Turbo Diesel Discussions - 335d > E60 m57 in to e90
      05-17-2020, 08:42 AM   #1
morreti
Drives: 335D
E60 m57 in to e90
hi all, I've got an m57 535D engine to replace an engine in my E90 335D... ive gone to do the swap and realised that the engine mount support brackets are different.
Is there anyway I can make this fit? All help would be appreciated.
Thanks
      05-17-2020, 10:01 AM   #2
RL18
274
Drives: 2011 335d sport
Thanks
Can't you just replaced the 535ds engine mounts brackets with the 335d engine mount brackets? From what I can see my x5d and 335d are exactly the same minus the second egr and how the engine mounts.
2011 335d tuned by B.R.R.
2011 X5 35d tuned by B.R.R.
      05-17-2020, 10:40 AM   #3
Yozh
Yozh's Avatar
No_Country
870
Drives: 2011 335d M-Sport
Are you saying that block mounting is different.
      05-17-2020, 01:05 PM   #4
morreti
Drives: 335D
Yeah block mounting is different... i don't have the 535 mounts and the 335 mount holes don't line up.
Arw the turbos different on the 535 to the 335?
      05-17-2020, 02:35 PM   #5
Yozh
Yozh's Avatar
No_Country
870
There are usually all the mounting points fir various combination. I trust you tried different positions. Turbos should be the same. Front cover is the same. I take manifold is slightly different. Turbo control system is a bit different as well. As is the CCV system.
      05-17-2020, 02:38 PM   #6
morreti
Drives: 335D
Yeah ive tried all different positions for the mounts. Im going to have to modify the 335 mounts. Luckily I have the 535 manifold...
      05-17-2020, 02:40 PM   #7
Yozh
Yozh's Avatar
No_Country
870
Realoem shows same block for e90lci and e60lci. Unless you are using an iron block
      05-17-2020, 02:43 PM   #8
morreti
Drives: 335D
Its an iron block yeah
      05-17-2020, 03:44 PM   #9
Yozh
Yozh's Avatar
No_Country
870
So it’s a pre-LCI block? Btw, the motor mount arm for 335d pre-LCI and LCI seems to be the same. Unless pre-LCI 335d never came with an iron block. Interesting
      05-17-2020, 03:48 PM   #10
morreti
Drives: 335D
My 335 is lCI ive got a feeling I need to modify my mounts to make them fit.
      05-17-2020, 05:38 PM   #11
morreti
Drives: 335D
Also not sure if I'll have trouble with cas and dme
      05-18-2020, 12:18 AM   #12
Yozh
Yozh's Avatar
No_Country
870
You should not as long as you use all of your original equipment that hangs or hooks up to the motor. I would probably use your original valve cover. Check all other sensors like water temp and camshaft.
On the motor mount arm issue. May be see if anyone can measure for you the original e60 pre-LCI arms for that come with this motor.
      05-18-2020, 01:41 AM   #13
Tambohamilton
3058
Drives: E91 330d
So what year is your car? And what year is the donor engine? Are you sure your old engine wasn't N57?
      05-18-2020, 01:47 AM   #14
morreti
Drives: 335D
The donor car was a 2006 e60 and my car is an 09 e90
      05-18-2020, 01:48 AM   #15
morreti
Drives: 335D
I have the originaly mounts still but theyre snapped on the ends.
I will use as much of my original motor as I can.
      05-18-2020, 02:23 AM   #16
morreti
Drives: 335D
After a quick search I dont believe the 09 335d didnt used the n57.
      05-18-2020, 02:56 AM   #17
Tambohamilton
3058
Drives: E91 330d
N57 was in production from 2008, but not sure exactly for what models/markets, etc. Easy way to tell is to look at you old engine, and see if the vacuum pump is located on the front of the engine. If it is there, it's an M57. If not, it'll be in the sump with the oil pump, and it's an N57.
EDIT: Yes, you may well be right; doesn't look like the 335d got the N57 until 2013 in the F-cars.
      05-18-2020, 03:00 AM   #18
morreti
Drives: 335D
You've got to love bmw lol.
I just want a working car now
      05-18-2020, 08:50 AM   #19
morreti
Drives: 335D
So I've just realised that there's 2 oil pick up feeds on the doner engine and only 1 on my old one... is it safe to block up one of the feeds or will that starve my turbo and kill it?
      05-19-2020, 01:49 AM   #20
Yozh
Yozh's Avatar
No_Country
870
You mean the oil pump feeds? Can you swap an oil pump?
