Has anyone rebuilt their DISA valves in the N52 with metal parts?
05-15-2020, 04:02 PM | #1 |
179
Rep 429
Guys, I ordered the metal parts for my DISA valves but really need to find the concentrated formic acid (98%-100%). I just need a very small amount enough to glue the two casings. Maybe like 5-10ml I suppose. Chemical companies in Canada are not willing to deal with a retail customer at all, basically being total a$$holes about it, no exceptions allowed blah blah. And nobody really sells it over the counter.
Can anybody help me source it please? Perhaps you've done the job and have some left over? |
05-15-2020, 09:33 PM | #2 |
626
Rep 2,099
Ebay. That's where I got mine. They do the hazardous material declaration on their end. Put more than you think to make sure the whole surface bonds well.
05-16-2020, 10:37 AM | #3 |
179
Rep 429
I did look at ebay. will spend a bit more time looking there. got a link and seller where you got yours?
05-16-2020, 11:24 AM | #4 | |
626
Rep 2,099
https://www.ebay.com/itm/192570974501 |
05-18-2020, 12:16 PM | #6 | |
626
Rep 2,099
The key to look for is that it is doing a slight chemical melt so it can smooth out and bond. |
05-19-2020, 12:15 PM | #7 |
179
Rep 429
I found a small amount through a friend of a friend who works in a lab. 96%. hope 10ml is enough.
Bluewater328, did you put the acid on both halves or just one side of the box before merging them? in the instructions here they say only to put acid on one side: https://vanos-bmw.com/product/repair...n52t-n51-small I am doing mine because I want to track the car and really don't want to think twice about a piece of plastic blowing up my engine so a proper seal is important for me without any ghetto solutions Last edited by belcom; 05-19-2020 at 12:25 PM.. |
05-19-2020, 10:26 PM | #8 | |
626
Rep 2,099
BTW the newer designs of the large one already have the metal shaft. Smaller one still comes with plastic IIRC. When the unit goes bad, even the metal ones have potential to go bad. The shaft will try and separate from the gear below and I had about a cm out the top. If servo goes, servo goes...can't help that part if its worn. |
05-20-2020, 05:16 AM | #9 | |
179
Rep 429
08-18-2021, 05:30 PM | #10 |
Rep 8
Drives: BMW 328i E92
I did rebuild the small DISA valve with the aluminum kit before installing the 3si on my 328i. Highly suggest it. Pretty simple and didn't have any problems getting the acid to reseal the casing (ebay like $5), going to replace voltage regulator on alternator in a few days, so probably going to rebuild large DISA at same time.
ornicar136.00 |
