05-15-2020, 06:37 AM | #1 |
79
Rep 117
Brake Job. m40i
Has anyone done the front brakes yet on their m40i?
Is it possible to just replace the pads if the rotors are in good shape? Has anyone found any aftermarket pads that are good quality ? The dealer parts dept wants $550 CAD for just a set of front brake pads. A brake replacement at the dealer must be thousands. Any advice would be appreciated |
05-15-2020, 07:57 AM | #2 |
56
Rep 191
BMW UK want £350 for front brake pads, so I emailed EBC and they sent me this link. If the discs are within the limits I would do just the pads.Hope this helps. https://ebcbrakesdirect.com/automoti...-2017-/1004643
05-15-2020, 08:06 AM | #3 |
602
Rep 309
In my honest opinion, never put new brake pads on rotors that aren't resurfaced or replaced. You're better off ordering oem parts on line and finding an independent auto repair shop to do the job.
2018 X3 Xdrive30i
2019 X3 M40i 2004 Supercharged Acura TL 6MT, NAVI A-Spec 2022 M3 Competition XDrive |
05-15-2020, 08:21 AM | #4 |
806
Rep 1,906
been working on my bimmers for 15+ years, above is solid advice. I have tended over the years to stick with stock pads, but there are many others manufacturers parts available. buy online and you'll save $$$ on parts costs. FCP Euro is xlnt supplier in the States, lifetime warranty always, yes even on wear items, worth a look as you may be able to source from them.
05-15-2020, 08:46 AM | #5 | |
Deadly
1315
Rep 2,073
Of course they (as is the current one - making three) lease cars so go back after about that mileage. Bring back asbestos ... |
05-15-2020, 09:05 AM | #6 |
806
Rep 1,906
I have changed pads only on my X3 once,no issues. Rotors are not all that costly however, so if in doubt.....
And for Canadians pad slam is of real value, they are always spending the big bucks for latest/greatest hockey gear, car expenditures takes backseat to their sport 😉 |
05-15-2020, 11:12 AM | #7 |
626
Rep 1,044
Drives: 2018 X3 M40i, 2012 X3 Xdrive35
As long as the rotors are within spec and there is no vibration, there is no reason to replace them.
2016 Z06 Vette, 10.53@132
1984 Vette, 406, 10.23@131 2021 SQ5 |
05-15-2020, 11:19 AM | #8 |
1910
Rep 5,105
^ This. I've never had to replace rotors as long as their condition was not sub-par
'11 Z4 30i (retired);'11 X3 28i (retired); '15 M235i Stage 1 Dinan (recalled & crushed); '16 M235i Stage 3 Dinan (retired); '15 X3 28i (retired); '14 328i (retired), 2019 X3M40i (retired); Loaded '18 X1 (retired); Loaded '20 X3MC DG, Black/Tan Merino (retired); Loaded '23 X1 Cape York green and Red/Black interior; '23 Audi A4 Allroad Progressiv
05-15-2020, 11:32 AM | #9 |
541
Rep 2,073
I've not done enough miles for a brake service in my G01, but in my F25 the reasons for changing rotors was with they were too thin or they had a lip which made fitting new pads problematic. Seems commonplace now, Is it because modern pads abraid the rotor more than in days of yore.
Current: G01 M40i Silver / Tartufo
Previous: E30 318iS, E39 520i 523i 523i, E46 vert 330i 330i, E93 vert 335i, F25 30D 35D |
05-15-2020, 12:15 PM | #10 |
10995
Rep 32,881
Something to note on these brakes is that the pads are bonded to the caliper pistons, that is they have a special high heat resistant 3M double sided tape on them. This is how BMW cured the horrendous brake squeal issues that were present on the Fxx M Sport front brakes.
Zimmerman do a pad that fits now, and they appear to have the 3M tape on them: https://m.autodoc.co.uk/zimmermann/14924663 Care needs to be taken when fitting that all the caliper pistons are properly cleaned and degreased, and then pressure applied to the brake pedal to bond the pads properly. And you don't need to change the discs as long as they're easily above minimum thickness, which is 34.4mm on these discs (they start at 36mm), so I'd say anything above 35mm and they are fine for another set of pads. |
05-15-2020, 12:46 PM | #11 | |
1910
Rep 5,105
05-15-2020, 02:01 PM | #12 | ||
10995
Rep 32,881
I would think the sticky pads affect brake feel too much for M division to fit them to one of their cars, but I may be wrong. |
05-15-2020, 02:09 PM | #13 | |||
1910
Rep 5,105
05-15-2020, 02:11 PM | #14 | ||||
10995
Rep 32,881
BMWZ41909.50 |
05-15-2020, 03:26 PM | #15 |
144
Rep 317
Not sure if pads are bonded to caliper as it looks like there was a bit of a "sticky" situation to remove oem pad from this youtube video (who i think is also a forum member here).
Seems a pretty straightforward and an easy way enough job to me, though I would watch carefully and write down all the steps if I had to the break job on my own. |
teaston10994.50 |
05-15-2020, 03:40 PM | #16 |
360
Rep 773
If love some brake pads that give off less dust, like A LOT less dust.
Present: 2019 X3 M40i Phytonic Blue
Past: 2013 335i xdrive Estoril Blue 2011 328i xdrive Black Sapphire Metallic |
TheusBimmer144.00 Alias1431795.00 |
05-15-2020, 03:53 PM | #17 | |
144
Rep 317
Adding link to ceramic low-dust pads: Ceramic low dust brake pads https://x3.xbimmers.com/forums/showthread.php?t=1659332 |
Alias1431795.00 fricfracfrank360.00 |
05-15-2020, 05:26 PM | #19 |
79
Rep 117
The video on you tube is what inspired me to replace my own pads. The front calipers are brembo and the pad replacement is simple. Issue is BMW has locked up the availability of the pads. I am almost certain this same caliper on the m40i is used on another BMW but it's hard to know which. I ordered EBC red stuff ceramic pads that the online tool said fit the m40i only to find out they don't. it's too bad there isn't a aftermarket pad better than OEM at a reasonable price as $550 CAD seems insane for a set of pads from the dealer. I wouldn't mind paying for them if I didn't think I was getting ripped off!
Alias1431795.00 |
05-15-2020, 06:03 PM | #20 | |
10995
Rep 32,881
Top pic is other models, bottom pic is G01: |
