Studio RSR
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N57 / M57 Turbo Diesel Discussions - 335d > help chasing fault code P0611 on 335d
      05-10-2020, 10:09 AM   #1
njmaier
Drives: 2011 BMW 335d
I have a 2011 335d that is having some issues. In the past it has had some issues where the car would throw the P0087 code for low rail pressure when driving aggressively. Sometimes it would kill the motor, but when you restarted the car there were no issues. The car would run fine until it threw the fault again intermittently. It only really happened when driving aggressively.
So yesterday I was having a little fun. While accelerating hard the car stumbled, started running really rough, and eventually died. I immediately tried to restart it but it would just crank and not fire. I waited a minute or two and tried again and it fired up but ran very rough like it was missing on a few cylinders. I put it in D and tried to move the car but it would barely run...sputtered and bucked and just wouldn't go anywhere and eventually died. I went through this process repeatedly and was able to limp it home.
I let the car sit for an hour or two then tried to start it again. It fired up but ran poorly. After a few minutes it seemed to clear up and ran close to normal. I shut it off and let it be for another few hours. I then started it back up and it seemed to run as normal with no issues. That's where I left it.
I pulled the codes and the only code was P0611 "Fuel Injector Control Module Performance". What do I need to start looking into with that code? Isn't the injection control part of the DDE? The issues definitely seem fuel related. Have I dropped an injector or two? I thought there would be more codes if it was an injector. Just looking for a little guidance.
My car is fully deleted and tuned with 104K miles
Thanks!
      05-10-2020, 09:02 PM   #2
maryjane
95
Drives: 2011 335d Msport 3 Snail.
What tune? BPC was pretty famous for blocking CEL codes.
      05-11-2020, 12:25 AM   #3
Yozh
Yozh's Avatar
No_Country
870
Drives: 2011 335d M-Sport
Do you have some BMW specific tools to pull BMW codes. Fuel system is my most hated to diagnose. There are so many things that could affect it and they are all interrelated. Start with bmw specific code then with specific diagnostics to eliminate system components one by one.
      05-13-2020, 08:59 PM   #4
njmaier
I am BRR tuned.
      05-13-2020, 09:02 PM   #5
njmaier
Finally got it hooked up to ISTA. Here are my codes...the ones at the 165km-167KM mark. #6 injector going out? Or something else?
      05-15-2020, 01:44 AM   #6
Yozh
Yozh's Avatar
No_Country
870
You had your battery disconnected at 165,880.
Your 4BD9 is an electrical fault for injector 6. Unless your plug or wiring is not seated or compromised This means your #6 is going out. Any water damage? 335d usually does not get water issues. Your rain trays in place. Not cracked. Never washed your motor, I hope. Before you go and run to get a new injector. Test resistance between injector pins. Should be 182kOhm plus/minus 10kOhm. Also zero between each pin to injector body. Just make sure body has good contact. Also resistance between pins should be stable. Report back please.
      05-15-2020, 01:45 AM   #7
Yozh
Yozh's Avatar
No_Country
870
Also, how about you scroll and show other codes.
      05-16-2020, 12:32 PM   #8
njmaier
Thank you for the info. I don't think that I have any water damage but haven't checked. All of my rain trays are there and intact. I have never washed the motor down or anything, but I have only had the car for 4 months so who knows how it was treated before. I will get the car into the garage and tear it down and do some testing.
I can get the rest of the codes pulled. I unfortunately lost the laptop that had all the software on it so having to redo everything before I can hook it up.
Thanks!
      05-18-2020, 02:05 PM   #9
njmaier
Here are all of the codes from ISTA. I am checking the resistance today so will have that data soon.
      05-18-2020, 03:40 PM   #10
njmaier
Does the injector need to be out of the head to test the resistance? I’m not getting a reading on any of the injectors. I know my meter is good...tested on several other items like a fuel injector out of my Mustang.
      05-20-2020, 01:51 AM   #11
Yozh
Yozh's Avatar
No_Country
870
You don’t need to pull the injectors. But you do need to remove the manifold to be able to unplug the connectors and reach the pins. I would focus on the rear three. This video might help with the manifold.
      05-20-2020, 07:17 AM   #12
njmaier
Yep I have the manifold off. I’m not getting a reading on any of the injectors. Not sure what I’m missing since I can get a reading on some old injectors out of my mustang.
      05-20-2020, 11:06 PM   #13
Yozh
Yozh's Avatar
No_Country
870
Are you measuring across the pins? Sure you got good contact?
      05-20-2020, 11:16 PM   #14
njmaier
I’ve got one lead on one pin and the other lead on the other pin. Seems like I have a good connection...same as when I tested with the old injector I have.
      05-21-2020, 11:38 PM   #15
Yozh
Yozh's Avatar
No_Country
870
You should be reading at least something. I’ve only seen one completely dead one with no reading at all.
      05-23-2020, 08:37 AM   #16
Mik325tds
Mik325tds's Avatar
806
Drives: 335d M-Sport
You need to clear all codes first and then see what comes back. With undervoltage issues there a many troublecodes set that don't necessarily point to a problem. Clear all, read again immediately after and then after a few miles of driving.
      01-03-2021, 10:12 AM   #17
Stevemeister
Stevemeister's Avatar
Drives: 2010 BMW 335d
What was the final issue and resolution with this problem?
      01-03-2021, 07:07 PM   #18
njmaier
Ended up being yet another bad #6 injector...simple as that.
