05-03-2020, 09:26 AM | #1 |
229
Rep 625
BMW X3 m40i vs X3M - 20 wheels
Hello,
I was researching and couldn’t find details. Anyone know why X3m has 255/45/20 front and 265/45/20 wheels while m40i has 245/45/20 front and 275/35/20 wheels? I was considering m40i but prefer all four wheels to have 45 profile living in Chicago that would benefit from pothole capital. Would It be ok to put 45 profile on the m40i in the rear with the same 275 tires or will that screw up the variance from speedo a lot? Any advice would be great as well as explanation regarding these two models tires setup in oem form in 20s. Thanks! |
05-03-2020, 10:10 AM | #2 |
Cowboy Astronaut Millionaire
2314
Rep 2,885
Good questions subscribing.
05-04-2020, 05:58 AM | #4 |
109
Rep 133
What size are your rims?
Tire width (mm) x Sidewall ratio (%) = sidewall height. 275/45R20 = 754 diam. Last edited by DoubleZeroNineOneEight; 05-04-2020 at 06:28 AM.. |
05-04-2020, 10:40 AM | #5 |
229
Rep 625
Unfortunately, I'm not understanding what I should get out of the chart. I appreciate you populating it but if you can put a little note answering my original question that'd be great!
05-04-2020, 10:59 AM | #6 | |
144
Rep 245
My Garage
Former: 2006 E90 330i, 2011 E91 RWD MSport Current: 2012 F30 328i, 2020 G01 M40i |
05-04-2020, 11:26 AM | #7 | |
229
Rep 625
05-04-2020, 11:40 AM | #8 | |
144
Rep 245
The X3M has 45 all around, because the tire widths are closer to being the same (255/265 vs 245/275). What you are thinking would keep things equal with all four tires having the same width, but that isn't the case. On a square setup, it would be like having 45 profile tires on the front with 50 profile tires in the back...
My Garage
Former: 2006 E90 330i, 2011 E91 RWD MSport Current: 2012 F30 328i, 2020 G01 M40i Last edited by PostModernHero; 05-04-2020 at 11:52 AM.. |
05-04-2020, 11:40 AM | #9 |
79
Rep 143
I investigated this possibility when I bought my X3 last October, and after lots of conversations with quite a few people, it became clear that having a 45 aspect ratio on a tire, vs a 40 will not offer any more protection against potholes. I spoke to a BMW technician, the people at Tire Rack, and a tire store here in the New York area, where we suffer just as badly from potholes as you do in Chicago. Changing to the X3 M size won't help you at all that way. One thing that can help is switching to non run flat tires.
This is just something that comes with the territory of having lower profile tires. Good luck. |
05-04-2020, 11:48 AM | #10 | |
2314
Rep 2,885
AAAAh so it seems. If the tire is wider but has the sidewall # lower it will still equal the same sidewall of a narrower tire.
05-04-2020, 11:49 AM | #11 | |
10995
Rep 32,881
If they really are available in those sizes in US, I guess they're a compromise made for the american market. |
05-04-2020, 11:53 AM | #12 | |
229
Rep 625
Honestly, I would now prefer to have the x3M 20" wheel size than the m40i |
05-04-2020, 11:59 AM | #13 | |
144
Rep 245
My Garage
Former: 2006 E90 330i, 2011 E91 RWD MSport Current: 2012 F30 328i, 2020 G01 M40i Last edited by PostModernHero; 05-04-2020 at 12:04 PM.. |
05-04-2020, 12:32 PM | #14 |
Internet Weasel
769
Rep 763
Drives: 2023 X3 M40i
If you're focused on having an aspect ratio of 45 all around, then I would just go with the square setup of 245/45-20. I kinda wish I had a square setup, TBH
I'm curious: you understand that 45 is a ratio rather than millimeters, right? That, I think, is what PostModernHero is trying to tell you. If you multiply the section width by the aspect ratio you get sidewall height: 275 x 40% =110 MM 245 x 45% = 110.25 MM So they essentially have the same 110 MM of sidewall rubber to fight off Chicago potholes. |
05-04-2020, 01:42 PM | #16 |
229
Rep 191
The general rule for all wheel drive vehicles is that dia (or circumferance) of wheel and tire should differ by no more than 1%. Hence 245/45/20, 275/40/20 M40i, 255/45/20, 265/45/20 X3M. The difference is likely in the interests of handing. Wider front tires give better front end grip which in turn allows for more rotation (i.e., less understeer or push). The all wheel drive system in the X3M is from the M5 and engineered for greater rear wheel bias than the M40i.
05-04-2020, 08:31 PM | #17 | |
1394
Rep 2,221
I have the 21 comp but run 20 square for my winter tires. OP - even with my 21 there is a fair amount of sidewall compared to my 19 E46 M3 Competition which wore basically rubber bands (and I bent a rim and split the sidewall on a pothole - Im NY). I learned its important to keep a high pressure as this will transmit the impact to the shock rather than the tire and wheel. Whats ironic about this thread is most X3M guys in the forum are complaining that they should have wider tires than the M40i and several have upgraded to larger sizes. |
