05-03-2020, 12:54 AM | #1 |
Newbie to G30
11
Rep 37
Fuse for the ashtray USB
This might have been discussed before but any ideas where I can locate the fuse for the ashtray USB, I tried to connect my phone so it can charge but no power.
05-03-2020, 11:13 AM | #2 |
1141
Rep 1,142
If the actual USB slot above the cupholders isn't working, it isn't a fuse causing the issue, as that connects directly to the headunit and if a fuse for that was out, you'd have a bunch of other issues. However, per the documents on the car, that particular USB slot isn't designed for charging, only the one in the armrest is.
Farravi11.00 |
05-03-2020, 12:09 PM | #3 |
103
Rep 231
If you search through this website, you will find an answer with diagrams of where the fuses are located: https://www.newtis.info/tisv2/a/en/g...ent/1VncUXgeU6
I'd begin by locating the fuse for the ashtray USB in the diagrams, and see what else is on the same circuit. Then see if these other items are operational. If they're also not getting power, then you know it's the fuse. |
Farravi11.00 |
05-03-2020, 10:28 PM | #4 |
4448
Rep 7,489
Did BMW not give the g30 5 series a fuse diagram & index sheet? If they did...you can locate fusse using that fuse index sheet. On the last generation...it was a laminated sheet folded up and inserted in the rear (trunk) fuse location. If you have that sheet and need help understanding it...post back with what you need help with.
2015 F06 650ix Gran Coupe`(Moonstone/Cohiba Brown)| 2014 F15 X5 50i MSport (Space Gray/Mocha)
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. |
Farravi11.00 |
