Anyone tried 255 tires in front?
09-17-2008, 01:56 AM | #1 |
36
Rep 1,467
Just wondering if anyone has mounted 255's in front.
I know 245's fit... so maybe 255's would too. (( I ask because there is a deal ($) on 4 255's. )) -scheherazade |
09-17-2008, 10:16 AM | #2 |
631
Rep 24,685
Drives: '04 330i ZHP
not sure but i KNOW 265 will rub... stupid tire shop put one of my rear staggered wheels in front when i got my 19's installed.
maybe you can still buy um and just sell 2 as rears? |
09-23-2008, 03:35 PM | #4 |
36
Rep 1,467
10-18-2013, 02:45 PM | #7 |
335 Newbie
23
Rep 484
Drives: 2011 335i xDrive
Anyone lowered run 255? I have 275 out back on my 19s and they rub, have to get my fenders rolled soon!
2011 BMW 335i xDrive, 12.2 @ 111 (e90 N55 XDrive Record)- Sold
Stage 2, Map 7/e85 mix, JB Intake, Vishnu Catted DP, ETS FMIC, CPe Chargepipe 1994 Toyota Supra, Baltic Blue, 6-speed, mods... FOR SALE 1200rwhp/875rwtq, 3.4L Stroker |
10-18-2013, 03:36 PM | #8 |
19
Rep 650
How do they look? Do you run a spacer in the front? I've thought about going square with 8.5" 162s, and running spacers on the rear only if it looked right.
10-29-2013, 09:12 PM | #10 | |
36
Rep 488
I've always run a square setup with 255 F/R. Did it on my E46 330 for 5 years. I like the look, the ability to rotate, and the handling change. I just mounted my rears up front to check fitment before I ordered rims and tires. JP |
10-30-2013, 06:18 AM | #12 |
1247
Rep 4,089
if lowered, they need some camber - and it depends on the actual section width of the tire as that varies from brand to brand.
but they *can* fit. no guarantees without testing though. |
10-30-2013, 07:54 AM | #13 |
27
Rep 280
255 will fit up front depending on wheel offset. Too low and you'll rub on the fender and too high and you'll rub on the strut. assuming you are running an 8.5 or 9 with anything close to the stock offset or 10-15mm lower, you should have no problems. I am going to be running a square setup this spring of 18x8.5 313 18" wheels with 255/35/18 PSS with a 10-12mm spacer. based on my calculations it will work with plenty of room and i am lowered on kw v3.
I hope you're putting these on an 8.5+ wheel up front. 255 is too wide for an 8" stock wheel. |
11-01-2013, 12:07 PM | #14 |
Major nutz
86
Rep 1,487
Drives: '09 n54 e92xi, 6mt, kw v3
Front rubbing depends on camber. I run 265/35/18 at all 4 with Yoko AD08s and track it extensively with no rub. 2.8d camber affords me no rubbing whatsoever up front. I get some rubbing with >200 lbs in back seat (so I can't put the in-laws back there when I track), though I think it would go away with a fender roll.
http://www.apexraceparts.com/EC-7-18...e-2_p_159.html Wheels specs: 18x9" ET31, 5x120mm, 72.6mm cb Tire spec: http://www.tirerack.com/tires/tires....D08R&tab=Sizes Hoosier in 255 is same width as AD08s in 265 so that is as wide as you can go with the purple crack (I love the purple crack): http://www.tirerack.com/tires/tires....R8R6&tab=Sizes Here's a recent pic with the 265 AD08s being "driven" by an unknown man on a dynamoter during an emissions test we all have to suffer on the Colorado front range.
11-01-2013, 12:19 PM | #15 | |
226
Rep 2,387
Any issues with excessive wear @ -2.8? How about harshness on the street with the Vorschlags? |
11-01-2013, 12:33 PM | #16 | |
Major nutz
86
Rep 1,487
AJ, "excessive" and "acceptable" are subjective I guess. I have 1/8 toe in, maybe even a little less, so I believe I get acceptable wear. I have more wear on the outside shoulder from, um, turning "spiritidly" and I can also rotate all four. So I even drive winter at -2.8d. I only drive maybe 500 miles all winter, so that probably has an affect on "acceptable". Vorshlags do make some noise and add some discomfort. My car sounds like a truck from inside too because I removed the head cover and the "tray" (for heat evacuation and because I got lazy - I change my brake fluid a lot). As long as it's acceptable to my wife, it's acceptable to me.
11-01-2013, 12:53 PM | #17 | |
226
Rep 2,387
I wish I lived near a track like you guys do but I would not like the front range craziness. What kind of brakes are those anyway, at first glance I thought you just painted the calipers. |
11-01-2013, 01:07 PM | #18 |
Major nutz
86
Rep 1,487
I bought these very ones. http://www.e90post.com/forums/showthread.php?t=618154 They took care of my "smelting" problem. If I ever go to Monarch/CB to ski/bike etc, I may look you up. You can drive the car. (Just not on your WWI driveway.)
11-01-2013, 05:31 PM | #21 | |
226
Rep 2,387
11-01-2013, 05:57 PM | #22 | |
Major nutz
86
Rep 1,487
Last edited by IN54NITY; 11-01-2013 at 06:20 PM.. Reason: Correction: 2000 Touring, not 2002 Touring |
