04-30-2020, 11:21 AM | #1 |
142
Rep 320
Transmission fluid change
Hello, my car a B58 x3 2018 with mhd stage 2 feels a little rough on shifts since the last 1000miles.
I got 40000 miles on the odo. I want to do a transmission fluid flush. Would liqui molly atf 1800 be a good fluid? Also do I need to change the pan? It's a lease and I'm returning the car in 1 year. Just want to have peace in mind. |
04-30-2020, 02:56 PM | #3 |
82
Rep 185
04-30-2020, 07:58 PM | #5 |
BMW Elite Master Tech | HV Gen 5 | HV Specialist
3511
Rep 4,211
Flash back to stock and see if trans is still not shifting smooth. Honestly if it's a lease I wouldn't do anything. Especially going so far as to replace the pan and drain and fill. I would recommend only OEM fluid though.
04-30-2020, 09:47 PM | #6 |
626
Rep 1,044
Drives: 2018 X3 M40i, 2012 X3 Xdrive35
And if it blows, that's what a warranty is for.
2016 Z06 Vette, 10.53@132
1984 Vette, 406, 10.23@131 2021 SQ5 |
05-01-2020, 10:41 AM | #7 |
142
Rep 320
I do not have anymore drivetrain warranty. Also I will have around 100000km on the car at the end of my lease. The last 20000km will have no warranty.
05-01-2020, 11:12 AM | #8 |
806
Rep 1,906
Suggest you consult a local Independent BMW/Euro car mechanic. Make certain a fluid change is the proper remedy.
Regards fluid: A system FLUSH is generally NOT recommended, a drain and fill is the normal service for transmission in these cars. The pan has an integral filter element, and it should be changed when fluid is renewed. I'd suggest you stick with OEM fluid (believe that is ZF Lifeguard) if you in fact get this service done. |
05-01-2020, 02:52 PM | #10 |
806
Rep 1,906
05-02-2020, 08:14 AM | #12 |
806
Rep 1,906
Using BMW/OEM fluid to refill insures all fluid in the transmission is of same type/characteristics; this to me seems more desirable than mixing two different fluids that likely vary slightly in chemical composition.
05-02-2020, 10:32 AM | #13 |
214
Rep 538
Do you not get three years warranty on a new BMW in Canada then? That would cover you until you plan to get rid of the vehicle next year.
I don't see the point in wasting money on extra servicing on a lease car. Its basically rented and if it breaks then surely its the lease companies responsibility to provide a another car or repair the car you are leasing from them? |
05-02-2020, 10:43 AM | #14 |
626
Rep 1,044
How many years is your lease?
05-02-2020, 10:44 AM | #15 | |
104
Rep 247
05-02-2020, 10:48 AM | #16 | ||
142
Rep 320
