BMW 5-Series (G30) Forum 2017+ BMW 5 Series (G30) General Discussions Bumper plug updates
      04-27-2020, 11:54 AM   #1
Muslenutz
Muslenutz's Avatar
55
Drives: Bmw 540 2018
Bumper plug updates
Guys, the paint didn't last 6 months here on my plugs. Any advice on how I can get the paint to stick? Perhaps when I got it detailed or when I used the pressure washer. I figured it would last longer. Materials used in attached.
      05-05-2020, 12:08 PM   #2
DobermanLV
DobermanLV's Avatar
Drives: G30 530iM
did you sand the plug prior to primer?
how many coats of paint? did you do clear-coat as top coat, how many coats of that?
Where did you get the plugs?
      05-05-2020, 12:12 PM   #3
Muslenutz
Muslenutz's Avatar
55
Lowe's. I didn't sand them, but I recently redid them. I sanded prior, 2 coats primer, 4 coats of paint, 4 coats of clear. All very thin coats. I think it was the pressure washer, they held up pretty well before that. Regardless I'll take some tips as they are still drying. I used factory touch up paint, bottles are very small. If I have to redo again, I'd probably do a spray option that's cheaper.
      05-05-2020, 03:16 PM   #4
DobermanLV
DobermanLV's Avatar
Drives: G30 530iM
Thanks for the Lowe's tip. Will go see, perhaps they have those in white.
      05-05-2020, 03:17 PM   #5
Muslenutz
Muslenutz's Avatar
55
Keep me posted. Perhaps Home Depot, but they never have them near me anymore.
      05-05-2020, 03:34 PM   #6
DobermanLV
DobermanLV's Avatar
Drives: G30 530iM
perhaps something like this would work?
https://www.ebay.com/i/301339309083
      05-05-2020, 03:37 PM   #7
Muslenutz
Muslenutz's Avatar
55
I had 6 holes under my plate that were drilled when I took it off. These are larger than what I have but may work. All depends on how much you want to spend and how much you want to put in. I just had a hard time with the paint sticking. Like I said, most likely my pressure washer.
      05-11-2020, 06:48 AM   #8
Titan2004
28
Drives: M550i/M50i/488/Maybach/RR
I use round cabinet bumpers with adhesive backs. Bought a sheet of black in various sizes and use the smallest ones that cover hole. Use med blue touch up paint. Much less obtrusive than plugs IMO
      05-11-2020, 12:21 PM   #9
Muslenutz
Muslenutz's Avatar
55
Got a pic? Interesting.
      05-11-2020, 01:26 PM   #10
Titan2004
28
Amazon $10.99 AUSTOR 318 Pieces Black Rubber Feet Bumper Pads
I think I used the smallest ones
      05-11-2020, 01:36 PM   #11
Titan2004
28
Smallest for top holes. Next size up for bottom holes in order to cover the holes in xpel. Yes, xpel installer poked holes through film after installing. Genius..
I have a ton of plugs but none fit as flush to bumper as these adhesive pads
      05-11-2020, 10:59 PM   #12
Muslenutz
Muslenutz's Avatar
55
Thanks bro
5post
