04-26-2020, 03:49 PM | #1 |
PWRDBYM
36
Rep 76
X7 M50i Race Chip Install Tutorial
Hey guys, just wanted to make a quick write-up with some pics on how to install a racechip for the M50i (I believe will work for JB4 as well, as that should connect to passenger and driver side boost pressure sensors).
As stated above, you will be connecting to the boost pressure sensors located at the bottom of both driver and passenger side intercoolers. Whole process took about 30 minutes. Step 1: remove silver cross-bars Step 2: remove drivers side intake snorkel (it's a bit difficult to get the intake removed from the bottom clips, but you can stick a screwdriver down there to assist. Step 3: with drivers snorkel removed, you have access to sensor. Connect the A cable in the racechip harness to this sensor. Step 4: you can remove the passenger snorkel however, I was able to access the sensor without removing. Step 5: connect cable B on the harness to the passenger sensor I decided to place the racechip on the passenger side next to the snorkel...there is a lot of room over here to tuck away. Step 6: connect harness to racechip and see if everything boots up. Start car and look for any CEL or alarms to pop up. Step 7: put all back together if no issues Step 8: take for drive on less aggressive map first to see if any errors come up and step up to next aggressive map...rinse and repeat. Hope this helps a bit. Feel free to message me if you have any questions. Shout out to Ben r33_RGSport for the racechip! |
04-27-2020, 07:50 AM | #2 |
39
Rep 60
Did you notice any issues with throttle tip in, shift smoothness or anything else? I had installed a harness like this on my panamera turbo and under full load it was fine, but on light to medium load it occasionally felt like it (engine/trans) was confused.
04-27-2020, 09:28 AM | #3 | |
PWRDBYM
36
Rep 76
r33_RGSport12971.00 |
04-28-2020, 11:08 PM | #4 | |
12971
Rep 18,716
Glad that you enjoy the product.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com PM for Everyday DEALS!! MSS • iSweep • RaceChip • Sterckenn • AutoTecknic • Akrapovic • Vossen Wheels • Eventuri Active Autowerke • KW • H&R • Ohlins • Remus • and more... |
04-23-2021, 03:16 PM | #6 |
2125
Rep 3,368
Any before and after dyno? A good friend just tried out a racechip on his f90 and yielded merely a 30ish whp gain. Not here to bash racechip, but interested as there is no tuning options on the newer dme's
04-24-2021, 07:26 AM | #7 | |
Rep 6
Advertised power increase to 700 HP and 700 Ft.Lbs. with an option to buy a warranty on the M50i |
04-24-2021, 08:56 AM | #8 |
2125
Rep 3,368
Now we are talking..I am a fan of buying if someone has dragy results or at least dyno sheet from same day/same car. JB4 seems like another option, but i'm not a fan of all the mentions of fueling codes/limp mode at WOT.
