ZPOST
Go Back   ZPOST > BMW Z4 Technical Talk > Engine, Exhaust, Drivetrain Modifications
  TireRack
      09-16-2008, 09:39 AM   #1
Evoking
95
Drives: Z4M Coupe
Eliminating Drone
Since some aftermarket exhausts can drone does anyone know if this drone elimination approach would work on the Z4M? Simple process of separating the pipes 1/4 of an inch so they don't reverberate off each other thus magnifying sound.
http://www.m3forum.net/m3forum/showt...07#post3313807
      09-16-2008, 09:41 AM   #2
iamwiz82
Drives: 2010 335d / 2012 MCS JCW
I don't want to register for another forum. Can you re-host the pics?
      09-16-2008, 12:26 PM   #3
Evoking
95
Drives: Z4M Coupe
Here is the fix on M3. Looks like nothing was done but apparently just a bit more separation makes a big difference.
Wonder if we could do this at the megaphone looking part before the x pipe. This is where it seems the pipes are the closest...
Name:  M3 Drone Fix.jpg
Name:  M3 Drone Fix 2.jpg
Name:  M3 Drone Fix 3.jpg
      09-17-2008, 02:11 PM   #4
ZStig
instagram 997turbotom
279
Drives: Interlagos Z4MR
interesting
      09-17-2008, 02:44 PM   #5
Dammmittt
My favorite sign.
Dammmittt's Avatar
South Korea
169
Drives: 2007 M Coupe
It's not quite that simple. What you're doing here is changing the natural frequency by adding the piece of metal in there. It's my guess that the small piece of metal there greatly increases the lateral stiffness of the pipes making the natural frequency higher (above what your engine can produce through RPMs).
The 1/4 inch of separation isn't going to make that much of a difference as far as acoustics are concerned. It's like saying that if you move your head 1/4 of an inch from a loud speaker you it would much quieter.
As an example to this, it would be interesting to see how different materials between the pipe change the natural frequency. For example, if you put a spunge between the pipes, then rubber, plastic, wood, aluminum, steel, etc. Each time you put something stiffer between the pipes, you should raise the resonant frequency, so the drone occurs at higher and higher RPMs, until you don't hear it at any RPMs.
07 ///M Coupe (Premium Package) Black Saphire Ext. Imola Red Int.
Best Website EVER!
zpost
