BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > UK > UK Technical Forum > 330D Induction
      09-16-2008, 05:43 AM   #1
GpAevo
GpAevo's Avatar
16
Drives: F31 320i
330D Induction
Alright folks,
Does anyone know of any company who does an induction kit for E90 330D???? Also any carbon engine covers/airboxs.
I've been looking for ages and can't find anything
      09-16-2008, 05:59 AM   #2
Ant397
Ant397's Avatar
45
Drives: X5 4.8is, Lambo Gallardo
We do a Performance intake for the 330d:
http://shop.speedreligion.net/air-intake-93-c.asp
It is not possible to fit a 'normal' cold air intake like some cars as the 330d's air filter sits along the whole side of the engine and only draws air though the large enough sized 'snorkel' from the grille area...
We have tried a whole range of air intakes for the 330d and find the K&N to produce the best benefits at a very cost effective price.
We have them in stock and are available for next day delivery if ordered through the website.
Have a look around, 330d's are our speciality and not many other people know them inside and out like us...
Anthony.
      09-16-2008, 07:12 AM   #3
MOB
MOB's Avatar
England
56
Drives: Alpine White M2 LCI
What difference would that K&N make to a remapped 330d?
      09-16-2008, 08:15 AM   #4
Ant397
Ant397's Avatar
45
The K&N offers greater airflow into the engine with less resistance. This does not mean that it allows more air in exactly, but it does directly improve volumetric efficiency, thus increasing mpg and allowing the engine to have more unrestricted air... removing restriction/improving efficiency is what tuning is all about, so with modern diesels, more power (bhp) can also mean more efficiency (mpg).
The change in mpg is evident all through the rev range and also shows an improvement of the engines willingness to rev toward to red line and also slightly reduces the turbo spool up time.
It is a noticeable modification that is very cost effective and can be swapped to further vehicles as the K&N is a serviceable item that carries a 1,000,000 mile warranty.
When you sell the car, simply remove it, put your current one back in and as the fitment is the same for any 3.0L d engine that BMW have ever made from 1999 to present day, from the first 184hp E46 330d's to the current E90 330d's, 325d's, X5's, X3's, 525d's, 530d's, 730d's etc etc.
When the air intake is combined with our free flowing performance exhaust, with either larger 330 style tips or our 335d twin exit system, increases of around 5 mpg are seen and the engine will rev to 5000 rpm like a petrol engine car.
You will definitely notice the difference.
      09-16-2008, 10:20 AM   #5
MOB
MOB's Avatar
England
56
Cheers! I'll be having one of them!
      09-16-2008, 11:58 AM   #6
Ant397
Ant397's Avatar
45
Cheers Mark,
Your order has been received and is being processed.
Anthony.
      09-17-2008, 07:19 AM   #7
330cdsport
Right Responsible
330cdsport's Avatar
58
Drives: AW F21 M135i
Originally Posted by Ant397 View Post
Cheers Mark,
Anthony.
Hi Ant,
Any news of a K&N replacement for the 335d yet?
Last: 330cd Sport - Silver Grey, 335d M Sport Coupe, F10 535d M Sport.
Current: AW F21 M135i, Coral Red, Pro Nav, Vis, HK, & Clunky Adaptive Suspension
Current: F15 X5 XDrive 40d M Sport - Space Grey, lots of toys.
      09-17-2008, 08:23 AM   #8
Ant397
Ant397's Avatar
45
Originally Posted by 330cdsport View Post
Hi Ant,
It is in hand and we should have a solution soon.
Anthony.
      09-18-2008, 10:27 AM   #9
MOB
MOB's Avatar
England
56
Cheers Mark,
Anthony.
Received today thanks
      09-19-2008, 03:48 AM   #10
Ant397
Ant397's Avatar
45
Excellent, do you need any fitting instructions/advice?
ant.
      09-19-2008, 05:34 AM   #11
MOB
MOB's Avatar
England
56
ant.
Yes please - where the hell does it go???
Nothing obvious under the bonnet
      09-19-2008, 05:40 AM   #12
Ant397
Ant397's Avatar
45
Its very well hidden... Ill prepare some instructions for you.
      09-19-2008, 06:06 AM   #13
Ant397
Ant397's Avatar
45
Here you go:
ant.
      09-19-2008, 06:43 AM   #14
hmi1750
hmi1750's Avatar
25
Drives: M135i
Wow.. I don't know if I would want to take it apart, may not be the same afterwards... how much do you charge for fitting this?
      09-19-2008, 07:24 AM   #15
MOB
MOB's Avatar
England
56
Well, I'm doing it as we speak...............pretty easy and logical, however.........
Last from bottom pic - what the hell are those bolts? They look like a star shaped socket should fit it - not a BMW tool is it?
Just of to Halfords to find one!!
      09-19-2008, 08:04 AM   #16
330cdsport
Right Responsible
330cdsport's Avatar
58
Thankfully they have sorted the airbox out in the 335d and the new 330d.
It is now a simple box at the front of the engine bay that is opened by 4 spring clips. You could change the filter in about a minute.
I remember putting a K&N into my E46 330cd and it took ages.
      09-19-2008, 09:10 AM   #17
Ant397
Ant397's Avatar
45
They are 4/5mm allen bolts.
      09-19-2008, 09:11 AM   #18
Ant397
Ant397's Avatar
45
As long as you dont break anything, it will all go back together 100%.
      09-19-2008, 09:59 AM   #19
MOB
MOB's Avatar
England
56
Right all done!
Those bolts above on my car need star sockets, available from Halfords.
Make damn sure you put the air filter in the right way up else the cover wont go back on, took me a while to figure this out,
Also helps if you loosen the strut brace bolts each side to get better access.
Quite a tricky job, but I managed it - thanks for the instructions Ant, I'd never have got near it otherwise!!
      09-20-2008, 11:48 AM   #20
Ti Rich
Ti Rich's Avatar
310
Drives: Porsche Macan S D
And is there any difference then?
      09-20-2008, 01:40 PM   #21
CrimsonRedE93
CrimsonRedE93's Avatar
108
Drives: Le Mans Blue E93 330d+
We wait in eager anticipation
      09-21-2008, 01:23 PM   #22
MOB
MOB's Avatar
England
56
Feels a tad more responsive - hardly surprising when the OEM filter resembles a sheep
Not a major difference but it all helps!!
