2011 335xi automatic to manual swap kit
04-18-2020, 09:56 PM | #1 |
1208
Rep 2,028
Up for sale is everything you need to do a n55 xdrive automatic to manual swap. Pulled from a 2011 335xi. * GS6x45bz 6mt Transmission * Pedal box * Accelerator pedal * Master cylinder and slave * DME wiring harness * Clutch lines * Grommets for firewall * Drive shaft * Manual radiator * Radiator hoses * Shifter, carrier, and shift knob * can include front and rear diff if needed (3.08) or keep your 3.46... |
04-19-2020, 04:14 PM | #3 |
1208
Rep 2,028
Yes, it would. You would just have the 45bz transmission instead of the 53bz. If you already have the N54 transmission I can sell you all the other stuff. It's all the same. You would just need to source an N54 driveshaft. N54 transmission is slightly longer.
The engine/dme harness would also be different but I think most people doing the swap are re-pinning their existing harness. Check this thread: https://www.e90post.com/forums/showthread.php?t=1207505 Last edited by bbnks2; 04-19-2020 at 04:26 PM.. |
04-19-2020, 06:36 PM | #4 |
49
Rep 139
Saw this done on Wheeler Dealers this past season on an older generation M3. Cool show plus they indicated that the modification added value to the car.
04-19-2020, 09:00 PM | #5 |
1208
Rep 2,028
Tags |
3.08, 6mt, auto, clutch, diff, n55, partout, swap, trans, xdrive |
