Rear tail lights
04-18-2020, 12:54 AM | #1 |
368
Rep 780
Drives: 2009 BMW 328i, Honda Civic Hat
Rear tail lights
Is it easy to take out and install rear tail lights?
04-18-2020, 01:20 AM | #3 |
368
Rep 780
04-18-2020, 01:43 AM | #4 |
1209
Rep 2,476
I have. Remove trunk liner/carpet around the tail lights, disconnect harness plugs, remove 3-4(I forget how many exactly) nuts and it pops out. The nuts, I think, are 10mm. It's been a while, but it's easy.
04-18-2020, 05:18 AM | #5 |
30
Rep 49
I have a 2009 coupe. On the right side, you remove the storage shelf over the battery, on the left there is the liner which you just pull off. On mine there are no screws, you just press on a center clip and the bulb assembly comes out.
04-20-2020, 09:05 PM | #8 |
765
Rep 591
Was just thinking. Are you getting repeated warnings about a light being out? If so, change the bulb first and if if the warning comes back, you likely have a faulty socket bracket assembly (the aluminum thing that holds all of the bulb sockets). Very common. Cheap to buy OEM and very easy to replace.
