04-11-2020, 07:42 AM | #1 |
Rep 10
Help please
I have a 2011 bmw f10 550 xdrive. Can I put these tire size without messing up the xdrive?
255-40-20 front 295-40-20 rear |
04-11-2020, 10:22 AM | #2 |
328
Rep 697
Drives: 2013 535xi
No.
You could go 255/35/20 and 295/30/20 without problems although the back might be too wide unless your wheel width is 10" or more. You could even go with 255/40/20 and 295/35/20, but these tires are oversized (larger overall diameter) than a stock size. Do some research on the threads within this section, as there are many, many, many recommendations herein.
2013 535xi, Carbon Black, beige interior, M Sport package, HUD, DDC & ARS, ACS springs, Kelleners wheels
2010 Z4 35i, Crimson Red, beige interior, 6sp manual, Adapative Suspension 2000 528i, Cosmo Black, beige interior, Sport package (retired) |
Hendrichs230.00 |
04-11-2020, 10:28 AM | #3 | ||
Rep 10
04-13-2020, 03:12 PM | #4 | |||
1569
Rep 29,202
F10 520d M-Sport Alpine White | HRE P43SC 20x9+20x11 | Michelin PSS 255/35+295/30 | KW V3 Coilover | M5 Front Sway Bar + M550d Rear Sway Bar | 3DDesign Front Lip | BMW M Performance CF Spoiler | BMW M Performance Diffuser | BMW M Performance Black Grills | BMW M Performance Pedals | |
Hendrichs230.00 |
04-13-2020, 04:07 PM | #5 | ||||
Rep 10
04-22-2020, 08:21 PM | #6 |
Rep 10
Hey y’all,
I just put on some 245/35/19 on some 19x9.5 with 10mm spacers in the front and I put some 285/35/20 on some 20x10.5 on the rear both with 35mm offsets and I’m running into some error codes is this normal? Is there a way I can remove the error codes and tune my speedometer to cope with the staggered offsets ? These went on an F10 535I I’m not having any running issues in the front or rear. Thank y’all for any information you can give ! |
04-22-2020, 10:23 PM | #7 | |
328
Rep 697
Drives: 2013 535xi
245/40/19 front and 285/30/20 rear.
04-23-2020, 11:15 AM | #8 | |
Rep 10
04-23-2020, 08:59 PM | #9 |
328
Rep 697
Drives: 2013 535xi
Sorry, I've never done coding or otherwise worked around error codes. I also think that your car won't look right since the rear tires are so much larger in diameter than your front. I'm curious if a 'professional' recommended your tire sizes, since they really are not well matched. Good luck!
