04-10-2020, 08:10 AM | #1 |
5219
Rep 3,932
Ride height measurement - 330i/M340i, RWD/AWD, Adaptive/Standard
I'm bored sitting inside like most of the world, so I wanted to see if anyone else was willing to help with some measurements. I've seen a lot of discussion around whether the RWD versions are lower than the xDrive...or the 330i vs M340i...or adaptive suspension vs fixed M standard suspension.
So here we go (hopefully I'm not the only one to actually do this lol). Measure from the center of the BMW roundel on the center caps to the top of the fender - see picture below. Do this front and back and fill in the following: Model - M340i Drivetrain - xDrive Suspension - M Adaptive Suspension Fuel Level - 1/2 tank Front Measurement - 14.5 inches Rear Measurement - 14.5 inches
Current: 2024 BMW M3 Competition xDrive | 2022 Audi Q7
Gone: 2022 Audi RS5 | 2020 BMW M340i | 2019 Audi RS5 Last edited by Burrcold; 04-10-2020 at 10:30 AM.. |
04-10-2020, 09:30 AM | #2 |
101
Rep 114
I was up for this, but I have a M340i, xDrive, adaptive suspension with exactly 1/2 tank of fuel :-(
Digital drive: F90 M5
Analogue drive: Ariel Nomad |
04-10-2020, 09:45 AM | #3 |
Rep 4
Model - 330i
Drivetrain - RWD Suspension - M Sport Suspension Fuel Level - 3/4 tank Front Measurement - 14.5 inches Rear Measurement - 14.5 inches |
04-10-2020, 10:08 AM | #4 |
5219
Rep 3,932
It would still be good to have a few measurement of the same just to rule out any mis- measurement or other factors?
Gone: 2022 Audi RS5 | 2020 BMW M340i | 2019 Audi RS5 |
04-10-2020, 10:30 AM | #5 | |
5219
Rep 3,932
So this is why having multiple people measuring the same models will eliminate the margin for error. I just went out and realized that my measurements are off because I was measuring from the top of the fender to the center of the cap, but quickly realized the cap is inset as the rims are concave. Measured again and sure enough it was bang on 14.5 inches (front and back) as well.
04-10-2020, 10:41 AM | #6 |
927
Rep 1,496
Might be easier to ask for fender to ground, that's more of a standard measurement for ride height...
| M-Performance Exhaust | JB4 Map 4 on E35 | BMC Red Panel Filter |
| Previous: 18 M3 ZCP | 17 M3 6MT | 15 M235i | |
04-10-2020, 11:06 AM | #7 |
5219
Rep 3,932
Fender to ground is not the way to do it. Tires size, rim size, tire pressure, etc will change the measurements for everyone. The fender and the center cap are the only two static points.
dancing__narwhal141.50 |
04-10-2020, 11:09 AM | #8 | |
927
Rep 1,496
04-10-2020, 11:23 AM | #9 |
5219
Rep 3,932
Reduces the variables from car to car comparisons, since only sprung weight is going to impact the fender to center cap measurement (which is why I asked about fuel level...I'm making an assumption that nobody is doing this measurement with a person in the car).
04-10-2020, 02:18 PM | #11 |
773
Rep 1,113
According to BMW the XDrive version is .3 inches taller overall.
2003 11/02 Steel Gray Metallic on Red M3 - SMGII - VF570 - SUPERSPRINT - KW - BBS - CSL ROOF SOLD
2015 09/14 Alpine White on Red 435i xDrive MPPK - Expensive black vinyl with special lettering. SOLD 2020 12/19 Mineral Gray Metallic on Black Vinyl interior M340i xDrive |
oz555671.00 |
04-10-2020, 03:14 PM | #12 |
5219
Rep 3,932
But then I've heard that the Adaptive M Suspension lowers it by about the same. So far it looks like all variations have been 14.5. I'll wait to see more people logging measurements. Unfortunately we don't get the RWD version in Canada so I can't measure myself.
DanVlnStud40.00 |
04-10-2020, 11:51 PM | #13 | |
3498
Rep 2,361
Burrcold5219.00 |
04-11-2020, 06:03 AM | #14 |
5219
Rep 3,932
Thanks! We have winter rims/tires on for 5 months of the year. I want them to look as good as possible since it's such a long time. I don't like going down a size or getting super narrow tires. Just doesn't look good imo.
04-11-2020, 08:44 AM | #15 |
4008
Rep 3,537
Drives: 328d Wagon, M2 Comp, i4 eD35
Model - 330i
Drivetrain - sDrive Suspension - Base Suspension Fuel Level - 1/2 tank Front Measurement - 15.5 inches Rear Measurement - 15.25 inches Measurements taken on the driver's side. I'm surprised the M-adaptive and M-Sport suspension has equal hub to fender measurements front and rear. Typically bmw has a larger measurement in the front. What "two letter codes" are on the springs on your cars? You should be able to see the tag by jacking the car up, but don't need to take the wheel off. The codes correspond to a specific PN and are the only way to ID springs since no PN is put on them. The 330i sDrive base suspension I looked at had code "AE" in the front and "BB" in the rear. Last edited by FaRKle!; 04-11-2020 at 09:36 AM.. |
04-11-2020, 06:51 PM | #17 |
5219
Rep 3,932
I'm guessing fuel level isn't too important. Hopefully we get more people contributing, but it seems like 14.5 inch is across the board (with M Suspension) regardless of 330i or M340i, RWD or xDrive, adaptive or fixed suspension.
04-11-2020, 08:02 PM | #18 |
736
Rep 1,261
Model - M340i
Drivetrain - xDrive Suspension - M Fixed Suspension Fuel Level - 3/4 tank Front Measurement - 14.5 inches Rear Measurement - 14.5 inches |
09-23-2020, 02:40 PM | #19 | |
40
Rep 139
My car came back from the dealer about 1.5 inches higher and of course they are saying it's to spec. |
09-24-2020, 08:10 AM | #20 | |
328
Rep 425
09-24-2020, 10:28 AM | #21 |
5219
Rep 3,932
It doesn't matter what kind of wheels you have if you are measuring from the center cap to the top of the fender (this measurement takes wheel and tire size out of the equation). To answer your question though, I have the staggered 792M 19" wheels.
09-24-2020, 12:10 PM | #22 | |
328
Rep 425
I'm not concerned about the measurement at all, your pic caught my eye because it looks like you have the 437M wheels in the photo, which is what I was trying to get for my G20 but my understanding is that the G20 bolt pattern wouldn't work on the 437M wheels from the F80. Maybe my eyes are deceiving me since you are saying they're 792M.... |
