      04-07-2020, 10:07 AM   #1
MrFoxy
MrFoxy's Avatar
Scotland
377
Drives: F40 M135i. G42 M240i
Pan Roof Noise
Anyone got a Pan Roof that makes a small creaking/clicking noise? Mine is right side of the car, me being 6ft 3" I'm picking it up a lot and it's beginning to drive me bananas!!
Tried WD40 and light bearing grease on the gaskets and any working parts I can think of, anyone having the same kind of issue?
      04-09-2020, 07:43 AM   #2
EvilDrPorkChop
EvilDrPorkChop's Avatar
951
Drives: Porsche Cayman
Have you got a wider shot of the Pano Roof? It looks nearly the same to our Mini one, which if it is the same cassette, creaks and knocks loads! I've found if you apply pressure up wards on the corner on the left or right side where it tilts up/down it stops the noise. Said noise resumes after letting go, tried adjusting ours to no avail, it's on my to do list to investigate further!
JustChris17487.50
      04-09-2020, 08:06 AM   #3
MrFoxy
MrFoxy's Avatar
Scotland
377
I'll get a shot once the wife gets in mate, a full shot closed/open?
      04-09-2020, 09:10 AM   #4
EvilDrPorkChop
951
Both if you can, but from the shots you've took it looks nearly identical to ours in our F56
      04-09-2020, 10:09 AM   #5
MrFoxy
MrFoxy's Avatar
Scotland
377
I still get the noise with the roof open mate
      04-09-2020, 10:30 AM   #6
EvilDrPorkChop
951
Yours is slightly different to ours, although pretty much the same concept - as it retracts externally rather than internally you find in the more expensive range of cars.
Ours only knocks and rattles when it's closed - so it only annoys us in winter as we usually have it open or on tilt most of the summer.
The two things I will say on researching the issue with ours is the cassettes don't get screwed in well enough at factory - resulting in knocking and creaking. The other main culprit is the sun blind too - both these issues would cause a noise when it's still open.
MrFoxy376.50
      04-10-2020, 04:13 AM   #7
MrFoxy
MrFoxy's Avatar
Scotland
377
Thanks mate, I took out the gasket and smeared a film of grease on the insert, seems to have worked better than anything else so far.
