BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > DIY Guides > DIY: Vorsteiner CF Trunk
      09-13-2008, 11:44 PM   #1
rzm3
Moderator
rzm3's Avatar
673
Drives: E92 M3
Arrow DIY: Vorsteiner CF Trunk
Note: I would highly suggest buying the following parts instead of transferring from your OE trunk:
1) Badge 51 14 7 146 051. No grommet needed as the badge already has double sided tape included
2) Stop buffer: 51 71 7 162 385. Use double sided tape to mount.
3) Expanding nut for license plate holder: 51 12 7 020 321
1. Mount the new trunk -- Partially attach the upper screws so that you can "hook" the trunk onto the hinges. Slightly tighten screws so that the trunk is not loose. Close trunk and check for fit. Adjust the trunk as needed.
2. Insert the wire harness. Install stop buffers. Install expanding nuts for license palte.
3. Install lights. Could be tricky because the CF sheets may be thicker than OE. Do it carefully.
4. Install license plate lights and trunk switch. Note: plate lights in pictures are installed wrongly. Should be turned 180 degrees.
5. Install the latch and key catch (drill mounting holes as needed).
6. Install white wire retainer.
7. Check all electrical components and mount wires.
8. Install carpet.
9. Install badge from outside. Place badge on trunk to check fit, you may need to correct the mounting holes.
good references:
http://bmwfans.info/original/E92/ - for part numbers
http://www.bimmerfest.com/forums/sho...d.php?t=254181 - for remvoing trunk.
http://mileoneparts.com - order parts online
      09-14-2008, 11:17 AM   #2
skim7x
skim7x's Avatar
208
Drives: 335i, C63 AMG
2007 335i  [10.00]
what!!?!? AWESOME!!!! Great job!!!
'07 Space Gray 335i coupe - R.I.P.
COBB ProTuned | AMS | CP-e | BMS | Quaife
      09-26-2008, 01:34 AM   #3
montreal red
chris
montreal red's Avatar
278
Drives: White Boat
wow this is awesome! thanks for the write up... if i ever do my own trunk lid install, i'll be using this.
Current: 2013 F10 M5 & 2016 Mini JCW
2013 GLK350 (gone), 997.1 GT3RS (gone), 2009 WRX STI (gone), e92 M3 (gone)
      11-08-2008, 01:00 PM   #4
Speedtrap
57
Drives: A very fast car :)
Thanks for sharing as I am seriously thinking of getting one. Any more rear pictures?
      05-10-2009, 12:37 PM   #5
Blake
No_Country
752
Drives: Chevy Aveo
oh by the way, you might want to have a dremmel handy...i had a few areas where the components didn't fit and had to sand down ever so slightly. mainly, where the trunk opener switch is. also, it is not necessary to drill the roundel post holes out. all i did was 3m tape the roundel on. my logic is the fewer holes, the better.
      05-10-2009, 12:40 PM   #6
skim7x
skim7x's Avatar
208
2007 335i  [10.00]
True. I mostly had to dremel down the slots for the license plate lights because they were too small and the DVWP was too thick in that area so that the lights wouldn't clip in very well.
      05-10-2009, 12:49 PM   #7
ThorsHammer
ThorsHammer's Avatar
82
Drives: '09 BMW 335i Coupe
Or if you don't have a Dremel, a round file and triangle file will do the trick.
I picked up this set from my local AutoZone for like $8. Worked wonders for all the the areas that needed adjusting.
"SYONRA" is for sale! http://www.e90post.com/forums/showthread.php?t=366678 BSM '09 e92 335i | Performance: JB3, RR Catted DP's, INJEN DCI, Britalman Exhst, AA FMIC, FORGE DVs | Suspension: ST-V1 Coils, Hotchkis Chassis Brace & F/R Sways | Wheels: Bremmer Kraft BR03s, Brake Performance Rotors, Cool Carbon Pads, ECS Lines | Exterior: OEM Aero Lip/Rear, ****** CF Trunk Lid, BLUX5 Angels, M-Force M3 Sides | Interior: Passport 9500ci, Black Trim, M3 Wheel
      06-12-2010, 01:24 AM   #8
bavarian06
bavarian06's Avatar
74
Drives: e46 m3
Op,
from the time you done this, has the double sided tape kept the "stop buffer" in place? i was thinking if i need to get expanding screws to hold it in place instead.
      06-14-2010, 01:26 AM   #9
AlexMac@Alpine
34
Drives: 335i Coupe
great write up OP... if anyone is interested in buying one of these beautiful trunks please PM me for any information.. THanks
      07-15-2010, 02:28 PM   #10
SSDD
Reading > Posting
SSDD's Avatar
20
Drives: 09 E90 335i
I know it's old but big thanks for the writeup. Your effort and documentation are appreciated. Really helped me on my install.
      04-25-2012, 09:37 PM   #11
ramirez330i
MATTE
ramirez330i's Avatar
47
Drives: '13 VW Golf R
are the part #s for those first three things the same for an e90?
Search this Thread:
Advanced Search
