N53 Intake Booth Silencer Delete
04-03-2020, 02:07 PM | #1 |
46
Rep 183
N53 Intake Boot Silencer Delete
Forgive me if this is the wrong section,
But has anybody done a intake silencer boot delete on the N53? Any negatives to this? The silicone pipes are available for the N52, would this also fit the N53? The length and dia. The part number for the 52 and 53 are different on realoem |
04-03-2020, 08:44 PM | #2 | |
Rep 53
2007 BMW 328i e92
N52 Couple of mods |
aaronblack45.50 |
04-04-2020, 03:10 AM | #3 |
616
Rep 3,194
Drives: E92 325i MSport Coupe
Yes I've done it (on an N53). Can't honestly say I noticed any difference in noise or performance...
E92 pre-LCI 325i - Ohlins R&T; H&R spacers; M3 strut brace; Swift thrust sheets; 3 x chassis braces; diff brace; N53 V-brace; 034 subframe inserts; BMS clutch stop; BMS CDV; RE g/box mounts; Delrin shift bushes; Saikoumichi OCC; Cyba scoops; BMW Perf Exhaust; HEL s/steel brake hoses; M3 rear spoiler; Recaro Sportster CSs; M3 white dash LEDs; LED Angels; LED side repeaters; BMW Perf black grille; CSL reps; SSDD carbon diffuser; Monster Wrap black roof/clear front
aaronblack45.50 |
04-04-2020, 09:04 AM | #5 |
Rep 53
Yes for sure just take it off and get a silicone one.
2007 BMW 328i e92
04-05-2020, 07:13 PM | #6 |
2440
Rep 4,330
04-06-2020, 12:48 PM | #7 |
46
Rep 183
I'm aware of the mishimoto but has anybody used any of these flexi silicone tubes? Says it doesn't collapse under pressure etc.
If these do work, it would just be a matter of measuring the diameter etc. https://www.ebay.co.uk/itm/202755389127 |
04-06-2020, 01:07 PM | #8 |
616
Rep 3,194
Two things:
1) Those on your eBay link aren't big enough (in diameter) 2) It's ages since I fitted mine, but I'm pretty sure the throttle body end is a larger diameter than the MAF end. And it also helps to have a hose with the 'bend' built in. A bit like this one (though unavailable): https://www.amazon.co.uk/Custom-Sili.../dp/B06Y1TTW4Y Just my five penn'orth...
aaronblack45.50 |
04-07-2020, 03:29 PM | #10 |
2440
Rep 4,330
https://www.amazon.com/Custom-Silico...ct_top?ie=UTF8
rev motoring listing that says it's available. I think you can get it direct from rev motoring on ebay for less, that's where I got mine. |
aaronblack45.50 |
04-08-2020, 07:09 AM | #11 | |
46
Rep 183
