Help! Cracked Head? N51
03-29-2020, 09:03 PM | #1 |
12
Rep 15
Need help/advice on what to do. I have a 2008 328xi with an N51 engine. Today I was replacing the oil filter housing gasket, finished the job (including coolant bleed and top-off), went for a test drive came home with a low coolant warning. Upon inspection under the hood it looks like where the filter housing bolts to the head the head has cracked. It was not like this when I finished the repair. Has anyone ever come across this before? What should I do? Obviously very upsetting/concerning.
03-30-2020, 05:59 AM | #2 |
616
Rep 3,194
Drives: E92 325i MSport Coupe
Ouch! Sorry to ask this, but did you tighten the OFH bolts to the correct torque?
E92 pre-LCI 325i - Ohlins R&T; H&R spacers; M3 strut brace; Swift thrust sheets; 3 x chassis braces; diff brace; N53 V-brace; 034 subframe inserts; BMS clutch stop; BMS CDV; RE g/box mounts; Delrin shift bushes; Saikoumichi OCC; Cyba scoops; BMW Perf Exhaust; HEL s/steel brake hoses; M3 rear spoiler; Recaro Sportster CSs; M3 white dash LEDs; LED Angels; LED side repeaters; BMW Perf black grille; CSL reps; SSDD carbon diffuser; Monster Wrap black roof/clear front
03-30-2020, 12:35 PM | #5 |
12
Rep 15
Anyone have thoughts on what labor costs could be for replacing the head at an Indy? Concerned if this could turn into a question of whether it is worth it or not. FWIW the car has 135k miles on it.
03-30-2020, 03:41 PM | #6 | |
996
Rep 2,287
These engines last a whole lot more than that. I think you will find several member with 250K or more. If you go the replacement head route, try to get one that's 2008+ revised to minimize the lifter noises. |
03-30-2020, 03:50 PM | #8 | |
2440
Rep 4,330
you're dealing with temperature, oil and coolant all right there. the "on the car fix" may be to call a local fab shop and see if someone it will to tig it back together. gonna be hard to get the hole back exactly where it needs to be since you'll have to take the housing off to weld it back on. but that's a permanent fix. I'm really surprised that the mounting ear on the head broke off before something bad happened to the OFH honestly. like a one in a million kind of thing. |
03-30-2020, 06:37 PM | #9 |
@Lucky.330i
39
Rep 91
Drives: 2006 BMW 330i
I agree with nsjames ^ get a fab shop to weld it back together, its the most affordable solution. Other than the crack there, its likely a perfectly good head.
Edit: I did forget about this video, but you could attempt to just send it with some JB weld. Extremely frowned upon, and I can't guarantee it works but others have done it. https://www.youtube.com/watch?v=aVLoJe3JbFI |
03-30-2020, 07:45 PM | #10 | |
2440
Rep 4,330
but in my experience using JB weld as field repairs it always comes off if it's exposed to any fluids. edit: and if you're trying to find someone to weld it back together, call the local machine shop that all the racecar people use for work. They will know a guy, or be the guy, that can weld it back together. |
03-31-2020, 09:49 PM | #11 |
12
Rep 15
Thanks guys - got put in contact with a bmw Indy who saw the pic and is going to try and tig weld it. Had it towed down today. Fingers crossed hoping for good news.
CTinline-six6847.50 IllSic_Design2124.00 |
04-14-2020, 01:40 AM | #12 |
2188
Rep 5,002
04-14-2020, 04:23 PM | #13 |
17315
Rep 18,737
I think the head can be tig-welded. It will then need some artful grinding and finish hand filing. The hole alignment is not critical because for this hole, a thru bolt can be used at that position, so the hole can be redrilled in the head-side.
This is the 3rd instance of this issue I have seen on the Forum. I think it happens as a result of improperly fastening the OFH to the head. Meaning some people leave the upper radiator hose attached, or tighten down the 3rd bolt too much before the other two bolts (that thread into the head) are tightened. The 3 bolts should be tightened slowly and evenly in a cross pattern without the coolant hose attached. I think what happens is there is uneven pressure between the 3 bolts and the 3rd bolt is over torqued, which micro cracks the head. Once the head rapidly heats up, probably faster than the housing, the stress fractures the head |
04-14-2020, 04:35 PM | #14 | |
626
Rep 2,099
06-17-2020, 03:22 PM | #16 |
12
Rep 15
So it's been about 2.5 months since this happened, doesn't help that it was in the middle of a pandemic, but hopefully I am getting my car back this week.
Shop was looking for someone to try and TIG it while still mounted on the car in the interest of saving serious $$. Eventually we gave up on that effort and they pulled off the head, had it sent for welding and are going to re-bolt. Hoping for the best here, can't wait to have it back... |
02-25-2021, 02:15 PM | #20 |
12
Rep 15
bluewater328625.50 |
