Bimmerpost
4 Series
Technical Topics DIYs and Coding Discussions G20 ESys coding causing system failures
      03-28-2020, 09:53 PM   #1
kabongSteve
21
Drives: G20 340i xDrive
Hi all,
Anyone else experienced issues with system failing after coding.
I added 2VB (TPMS) to my car to use the tyre pressure sensors.
Since I was unsure which ECUs needed recoding, I recoded all ECUs.
I was also trying out the 3AC (Trailer Hitch) as I'd added a towbar and 3rd party ECU controller.
But now, my Parking Assistance is always a failure. All the senors and cameras are working, but the Assistance says its failed.
I tried another recode, and now Driver Assistance is also in error.
Using ISTA+ it suggests an ethernet failure, but no idea how to resolve this, or why a recode could cause this.
Anyone else had issues like this when coding?
      03-30-2020, 10:40 AM   #2
mrgicm
mrgicm's Avatar
441
Drives: BMW M
You can cose this with a 3rd party ecu controller. If you code something without the proper hardware you will get an error.
      04-23-2020, 05:11 AM   #3
kabongSteve
21
Well its all relative...
I finally took my car to BMW to get it sorted, and found that ALL the issues related to power loss.
Because I had disconnected the battery to install the towbar wiring, it decided to cause lots of faults.
So it seems it wasn't related to the coding at all, but the fact the battery had been disconnected.
A bit of a concern for the next time anyone needs to disconnect the battery
Appreciate 2
VipinLJ1941.50
g20
