BMW X5
      03-25-2020, 10:44 PM   #1
martinf79
martinf79's Avatar
191
Drives: 2020 G05 X5 M50i
Anyone else have this? Mine is a November delivery... so only about 5 months old.
Would a replacement be covered under warranty?
2020 X5 M50i | 2015 X3 28i xLine | Retired 2013 335i M Sport
      03-26-2020, 08:44 AM   #2
radmjk
radmjk's Avatar
No_Country
241
Drives: 2024 X5 M60i, 2020 RRS SE, 201
Have had mine since August 2019, so a bit longer than you. Seems crazy. I would definitely think and expect the dealer would take care of this. Sorry
RADMJK
2024 BMW X5 M60i Brooklyn Gray Metallic
2020 Range Rover Sport SE White
2017 BMW 530i xDrive Black
2005 BMW Z4 2.5i Jet Black
      03-26-2020, 09:45 AM   #3
MystroX5
MystroX5's Avatar
6290
Drives: 2020 X7 M50i/ 911
It’s not uncommon to see rust on the welds of the trailer hitch. I have seen it a lot on new pickups still on the lot. My solution for this is to wire brush the rust on the weld, spray a rust inhibitor on the welds and then give it a quick shot of semi gloss enamel. Pretty sure your dealer will do the same if you show it to them.
Appreciate 2
Tenac4538.50
BMWZ41909.50
      03-26-2020, 03:32 PM   #4
JFU
134
Drives: X7
+1
I'd much rather they don't do any replacing and just remove the rust and coat. Too many things can go wrong with a replacement like that. If you use the hitch at all, the receiver will eventually develop rust too.
2014 A207 E550 Vert
2018 F60 Countryman S All4
2019 G07 X7 40i
BMWZ41909.50
      03-26-2020, 03:35 PM   #5
Tenac
Tenac's Avatar
4539
Drives: All
It might be faster for you to due it your self. A bit of sand paper and good rustolem protection paint. You can even do clear.
2022 M8 Comp Convertible
2023 718 Cayman GTS 4.0
2019 718 Cayman Base
2015 M235 Manual
On the list for the M2 CS
BMWZ41909.50
      03-26-2020, 05:20 PM   #6
martinf79
martinf79's Avatar
191
Thanks all... that's what I was thinking as well. Just wanted to check in.... think I'll just take care of it myself. Dealer might fix it .. but for everything they "fix", I find another 2 things they damaged/broke.
      03-28-2020, 09:46 AM   #7
AustinV
AustinV's Avatar
113
Drives: BMW X5 40i (2019)
Yes it's very common for tow hook to rust, especially in our Canadian winter + coastal humidity weather mix. All my previous cars had this problem - Toyota Highlander, then Acura MDX. I normally claim it to the dealer and they do some touch ups which fixes it for couple months, then problem returns. I just checked my 2019 X5 which I had since last summer and survived the same rough winter that my other cars did. So far surprisingly not a drop of rust. Only thing I did different with this car - I sprayed it once with WD40 sometime around fall, perhaps it helped. Anyway now I'm going to do it again for the next winter
      03-28-2020, 07:39 PM   #8
James_G0540i
Australia
446
Drives: 2021 X5 G05 40i M Sport
Spray with a little WD40 (exact what AustinV said), wait 10 minutes then it should just wipe away. Also good for preventing.
If that doesn't work, use a fine metal brush and then some flat black paint and its gone.
Its very common for tow hitches to rust, especially around joints/corners or where rubbing has occurred to expose bare metal. As long as its only surface and hasn't penetrated into the metal, its not a problem.
I have the stealth/removable tow-hitch, which has a hidden coupling under the rear bar. This has a plastic filler-module that fits into the coupling when the tow-hitch is not in, stops water getting in and rusting the coupling.
Another advantage of hidden/removable tow hitches, less wear and tear on the tow hitch.
xbimmers
