03-24-2020, 04:39 PM | #1 |
46
Rep 121
Cockpit rattle
Since a week or 3 my car developed a new cockpit rattle.
I would swear the noise is coming from the right front, but sometimes this is misleading. Once i asked my father to drive it so i could sit in the passenger seat, but i found sitting in the passenger seat the sound was less noticable. When i drive and i have a passenger it makes no difference to the sound. I tried to make a video of the resonating/vibrating sound. https://1drv.ms/v/s!Aj3rz51JNcMYjppq...hmXiw?e=8e4lQX Turn up the volume and listen carfully. You can hear the sound good from 9-15 seconds and 29-33 seconds. Don't listen to the road or engine noise, but the sound in between there. Any ideas what would be the source of this. I have been through some thorough investigation already, but i have failed to find the source and i'm getting a bit desperate. The sound in real life is more pronounced than in the video. Any advice or tips will be appreciated. |
03-24-2020, 07:52 PM | #2 |
Rep 2
Mine has no such sound & I'm just a shade tree mechanic. Kind of hard to tell from your video. Not from the roof area? Check for any bumper grommets missing around the hood & is the license plate secure? This would be a hard one to diagnose from afar. Sorry. I think sounds in vehicles can be transmitted from places at the other end of the car, especially if it's somewhere in the drive train.
03-24-2020, 09:03 PM | #3 |
219
Rep 690
Drives: 2019 X3 M40i
Hi
Just so you don't think you are insane, I heard the rattle as you noted. You do need to be careful as in my experience with rattles, the car can actually transmit sounds from the back to the front and front to back. In my E90 I suddenly experienced a rattle at high speed and would have bet my life on it the sound was coming from the driver's side floor area. Turned out to be that I had used the sun visor to block the sun out on the driver's side window and when I swang it back I hadn't clipped it back back in and the arm was rattling against the locking clip....it did my head in for a week before I realised what was going on. Hope you find the source of your problem. |
04-05-2020, 05:41 PM | #4 |
46
Rep 121
As being in quarantine has given me lots op spare time i normally not have, o decided to look further to find my rattle.
I have spend about 5 days for 2 hours looking for the source of my rattle. I tightened up everything under the passenger seat, checked every cable and connector under the dashboard, checked the center speaker, the roof function center, the amplifier in the back, all possible lines and trim pieces under the hood. I have dampened with foam every little piece with some play on it that i thought it could be causing a rattle. I also checked all the panels under the car. I have to say that looking in all those areas the X3 has been well put together, but still i found some places for improvement. Anyhow, the result of all this work for the past 2 weeks has been that i still experienced the rattle i was looking for But as it was sunday today, and i had nothing else to do i had another go at it. Delving into the passenger side a pillar I removed the sound isolation. there where some holes underneath there, i started to feel with my fingers in there and there is noticed something was loose. Video: https://1drv.ms/v/s!Aj3rz51JNcMYjqQj...fm1Qw?e=7MbvQa There is a bolt that connects the dash to the frame and this was sitting loose. I tightened the screw and the rattle is gone Now i just wonder why the bolt was loose? Did become loose because of driving vibration, or was it never tightened properly from the factory... |
04-05-2020, 07:04 PM | #5 |
1910
Rep 5,105
Great job tracking it down. Personally, I would be thankful I found the rattle rather than worry about how it got there or if it will happen again and just move on
'11 Z4 30i (retired);'11 X3 28i (retired); '15 M235i Stage 1 Dinan (recalled & crushed); '16 M235i Stage 3 Dinan (retired); '15 X3 28i (retired); '14 328i (retired), 2019 X3M40i (retired); Loaded '18 X1 (retired); Loaded '20 X3MC DG, Black/Tan Merino (retired); Loaded '23 X1 Cape York green and Red/Black interior; '23 Audi A4 Allroad Progressiv
04-06-2020, 02:09 AM | #6 | |
795
Rep 1,959
04-06-2020, 07:52 AM | #7 |
214
Rep 538
My car developed a rattle after the windscreen was replaced. It appears to be from around the windscreen demister vent/centre speaker area. Anyway BMW are now removing and refitting the dash to fix the rattle. They removed it before the workshop closed due to covid19 and i'm now driving around in an X1 loaner until they reopen the workshop and put the car back together. Not overly impressed with the X1 if i'm honest and who knows how long this is going to be.
04-06-2020, 02:09 PM | #8 |
63
Rep 267
Great job locating it OP!
I have a rattle somewhere on the driver side door and centre console. Going a little crazy every time I drive but I know dealers are really bad with identifying rattles. How hard was it to remove the door panel? I feel like this is a project I can do now that we're all staying at home. |
04-06-2020, 04:31 PM | #9 |
795
Rep 1,959
It was fairly easy. Slightly more difficult than my old Honda Accord. Hardest part is probably accessing the two handle screws. Use a trim remover. I did break one of the perimeter plastic fasteners on the passenger door. Not enough to impact reassembly. Broke as a function of pulling it out, nothing you can really do to "be careful."
06-07-2020, 11:18 AM | #10 |
46
Rep 121
I thought before that i found the source of my problem with the loose nut at the dash. Sadly i realised that the noise still existed afterwards so the loose bolt was not the culprit.
So after 2 more months of desperate searching i decided to take off the a pillar cover again yesterday. Now suddenly i could hear the noise much louder than before. Video: https://1drv.ms/u/s!Aj3rz51JNcMYj4Fb...zN8VA?e=LcvRzb My conclusion is that the rattle is coming from inside the chassis structure of the A-pillar. I noticed there seems to be a cable running through there, sadly there seems to be no way to reach this cable to fix it down. So i decided to put some diy sound isolation behind the A-pillar cover to reduce the noise that reaches into the cabin. It is not perfect but the sound reduce by 80-90% to the point that it is almost unaudible. If i didn't know i would never notice it. At the next service i will ask the dealer if they know a solution to rectify it completly. |
06-07-2020, 03:10 PM | #12 |
46
Rep 121
09-01-2020, 04:41 PM | #13 |
46
Rep 121
My a-pillar rattle got completly resolved today by the dealer.
They found out that the source of the rattle was that the reservoir from the windshield washers made contact with a structure beam in the engine compartment which extends to the a pillar transmiting the noise into the cabin. I'm very happy they found it, i can again fully enjoy my car now. Also thumbs up to the dealer for resolving this. |
JDsX3507.00 chicagofan0019147.50 |
01-07-2021, 10:44 PM | #14 | |
BMW Elite Master Tech | HV Gen 5 | HV Specialist
3511
Rep 4,211
01-08-2021, 07:33 AM | #15 | |
Deadly
1315
Rep 2,073
03-26-2022, 01:45 PM | #16 | |
Rep 7
Front passager side rattle in interior
https://www.dropbox.com/s/tnw6x4m770...attle.MOV?dl=0 It sounds very much like it is coming from the front right corner (passenger side), but interestingly, similar to you tokke, when I sit in passenger side I hear it less than when I'm driving. But the video I took above is with my phone resting on the front dashboard in the corner of the passenger side. Have brought the car to dealership twice and both times they say they found the source and corrected it, but neither time did it get rid of it. So frustrated as this car is only a few months old and hoping someone here can help. And if it indeed is the washer bottle issue I'd be thrilled as I can then point that out to the dealer versus them "trying" to find the source. Thank you and hoping I can get some help here on this forum!!! |
03-26-2022, 07:37 PM | #17 | |
43
Rep 90
My kids (sitting in the passenger seat) insist that they don't hear anything, but it's SUPER loud in the driver seat and I'd describe as a "thunking", sort of like a tennis ball shaken in a coffee can. |
03-26-2022, 07:38 PM | #18 | |
43
Rep 90
05-09-2022, 02:16 PM | #19 | |
46
Rep 121
They resolved the problem by tightening down the reservoir from the washerfluid. This came loose and was vibrating to the chassis. This transmits into the cabin through the a pillar on the passenger side which is a part of the main chassis. The reservoir is not easy to reach in the engine bay, some parts needs to be dismantled. The dealer said that they had seen this problem also on the 5 series. I hope this info helps you. |
Chief Orman671.00 |
